$800 4 a 884runner what to look for? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-12-2008, 12:43 AM   #1 (permalink)
olharleyman's Avatar
I have a line on a 88 4runner going to check it out sunday might get it for 800 just wondering if anyone has any ideas on what I should or should not look out for? Here's what I know about it for now
5 speed
120xxx miles
3.0
33's
very stright body no rust
All of this is hear say from a friends dad so not to sure about how acurate it all is.
Thanks all
__________________
1990 4 runner 5 Speed
Pro Comp Stage II 4" Lift 6" coils rear
Aussie Locker front
5.29's Front And Rear
35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels
Super Charged 3.4 on the way
1993 SAS 4runner 22re 5 speed
4" front 5"rear
5.29's
35 x 12.5 BFG KM'S
Dick cepek DC 1's
88 stock 4runner
3.0 auto
for now
1955 Harley Davidson Springer
Stock 1955 Hardtail Frame
4 Speed
Kick Start Only
1998 Harley Custom Dresser
107 rwhp
139 ft.lbs.trq.
olharleyman is offline
Old 01-12-2008, 01:13 AM   #2 (permalink)
phildelfino's Avatar
Send a message via Yahoo to phildelfino
For 800 if it started and passed a smog I'd buy it in a heartbeat. I don't know what to look for, goods and bads of this model. I check the oil, coolant, brakes (run hands over rotors to check smoothness). I'd say the usual, check around steering box for cracks, windshield and chrome strips (they leak alot around windshield). Mine makes alot of noise (whistling) with the windows partly down or sunroof open. when test driving the usual, tracks straight, brakes straight and no grinding, no smoke out the exhaust.
__________________
1988 4 Runner w/225,XXX miles, 3.slow V6. A/T. 4.10s?-(G292 code) and power everything else that still works, except someone broke off my electric antenna. 1.25" BL. Used Marlin Crawler Rear Bumper, 33 x 12.50 x 15 on Steel Chromies w 3.5" BS. Has new shocks, leafs.
Soon; Trail Gear Sliders, ZUK brackets & coils, rear shock brackets & flip kit,
Wish List; Rear lockrite, 529's, sliders (got them for $100.oo, new in box), 5 speed swap
http://www.cardomain.com/ride/3171939
phildelfino is offline
Old 01-12-2008, 01:33 AM   #3 (permalink)
linuxrunner's Avatar
$800 makes it pretty easy, just take a look over everything, check the oil/coolant and start it up, if it runs good/ok and shifts good/ok 4wd works good/ok you have a truck worth 800 easy. If any 1 or more of these do not work, it's up to you to decide what it might take to fix it and if it is still worth it.
__________________
88 4runner 22re
Quote:
"Ditch that IFS because it is already crap and go for an SAS! (Single Axle Swap)"
linuxrunner is offline
Old 01-12-2008, 01:52 AM   #4 (permalink)
I'd take a look at the frame to see how bad the cancer is - depending no your area it could be well corroded, if it's really bad you'll not be able to pass a safety. It'll then make a good paper weight.
iam_turner is offline
Old 01-12-2008, 02:03 AM   #5 (permalink)
CyMoN's Avatar
ask about timing belt, starter, alt, brakes, clutch blower fan, rear window works.
if it has fender flares on it look behind them check the drivers side fender well where the clutch pedal is at for rust holes.
pop out the rear cargo doors and shine a light in to check for any bad rust.
if you buy the truck flush out the rocker panels and doors and rear panels with lot of water same as the frame.
when I bought my truck most things had been worked on but I did not check over a few spots and I had a little more rust then I had thought at first
but now the truck is going to under go an major over haul and I am cutting out the rust now that she sits there in the driveway just wanting to be driven.
for the asking price I think it is a really good deal as long as the body and frame are in good condition my 3.0 ran good most of the time only when it had rained out and when it was really cold did in have a slight problem but after it warmed up it ran like a top.
__________________
my rigs
89 4runner
1989 4runner v6 5 speed everything factory +4susplift running bfg 31s and a aux gas tank and more aux lights than needed
86 pickup
1986 stock pickup 22r 31.10 BFG ATs flatbed
a sad day for the 4runner
"One moment of patience may ward off great disaster. One moment of impatience may ruin a whole life."
CyMoN is offline
Old 01-12-2008, 02:03 AM   #6 (permalink)
idanity's Avatar
less than 1k for a 4x4 is awesome.
you could more or less part it out for more than 800 if it is a basket case.
but if it drives straight and is not a safety risk, (especially w/120k on it) its definately worth the look.
make sure the VIN # corresponds to the frame/body parts.
remember to check the
heat. (really old heater cores smell like wet fur)
horn
wipers
all lites (reverse/hazards , brake, etc.)
oil (look for burnt or black internals on the head (from the oil cap), this may indicate that it was overheated. should be golden brown cam and not too dark).
make sure the 4x4 works (i got my 86 for 1200 b/c one of the hubs was bad), easy fix if its the hub.
btw, the best cars ive ever owned were also the cheapest.
idanity is offline
Old 01-12-2008, 09:08 AM   #7 (permalink)
85toy's Avatar
make sure it idles smoothly and doesnt go up and down in rpms
__________________
1984 toyota pickup extended cab 4x4
couple of mods
Quote:
Originally Posted by Getsome View Post
Tuesday black tar herion night.
85toy is offline
Old 01-12-2008, 09:24 AM   #8 (permalink)
Banned fruitloop
4runnerchevy's Avatar
88
Heck if it drives decent to the smog shop and passes then buy it. Assuming you have smog laws where you live. $800 is a steal even if it has minor issues.
4runnerchevy is offline
Old 01-12-2008, 10:48 PM   #9 (permalink)
Well I talked to my buddie and he talked with the owner and he say's it's a 4 banger but even so I am going to check it out in the morning will get pics and post up tomorrow so ya all can check it out.
__________________
Aussie Locker front
4" front 5"rear
5.29's
35 x 12.5 BFG KM'S
Dick cepek DC 1's
88 stock 4runner
3.0 auto
for now
4 Speed
Kick Start Only
107 rwhp
139 ft.lbs.trq.
Old 01-12-2008, 11:05 PM   #10 (permalink)
Issues's Avatar
Heck if it runs & the fourweeldrive works buy it. You wouldnt find a running fourwheel drive no matter how the body & everything eles looks around my area for $800. If you did you proberly would need 5 gallons of bondo for the body. And sheet metal to cover up the holes in the floor board big enough to loose the family pet too, lol. Good luck, maybe it'll be a steal!
__________________
"Paved Roads.. Another example of wasteful Goverment spending"
Issues is offline
Old 01-12-2008, 11:17 PM   #11 (permalink)
88wildrunner's Avatar
800 for a 4runner with a 22re, how could you go wrong?
with only 120xxx miles i doubt it has any drivetrain problems and even if it has motor problems, you could drop in a new 22re for a grand that puts you back 1800 for a runner with a new engine, thats an awesome deal, and if the engine and drivetrain and overall condition is good i wouldnt hesitate for $800 bucks. seems like it would be a great start for a build.
__________________
I hate Thieves, especially the kind that steal 4runners
MY 4RUNNER BUILD
http://www.yotatech.com/f115/88wildrunner-build-125357/
88wildrunner is offline
Old 01-13-2008, 12:47 AM   #12 (permalink)
notanymore's Avatar
it has the 3.0 but either way 800 for a4runner is a pretty good deal, unless there is a serious issue with rust on the frame and such. being so cheap i would be sure there is some kind of problem with it, possibly the hg or blown motor. but either way its a pretty good deal.
__________________
my truck: 1987 pickup xtra cab sr5 22re 5 speed 4wd, 31x10.5's eb 261c cam, lce header, 2.25 exhaust 120amp Mr. Alternator rear lockrite, optima yellow top
xrc8 winch & AOR bumper coming soon
my bikes: 1980 Honda CX500-1997 honda cbr F3
notanymore is offline
Old 01-13-2008, 08:02 PM   #13 (permalink)
ewong's Avatar
Its kinda a catch 22 question.
If you had the "skills" and the need - $800 is worth it just for the usable parts
-- trans
-- xfer
-- block
-- interior bits and stuff that would kill ya in a swap project
Its in MD - so its not as bad as say MA, but RUST would be an suspected issue
-- rear wheel wells
-- frame at kick up
At $800 - one doesnt expect much...
ewong is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Considering selling built 884runner shawn The Classifieds GraveYard 21 05-25-2006 08:27 PM
Building an 884runner for mud. Tacoma750 Offroad Tech 9 10-07-2004 01:55 PM
800 hp from a Toyota V8!!! Yoda 95.5-2004 Tacomas & 96-2002 4Runners 3 10-01-2004 07:39 PM
800 HP from a Toyota V8!! Yoda 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 0 09-30-2004 07:09 PM
Nu be here. What is the toyota 1 800 # dad4 95.5-2004 Tacomas & 96-2002 4Runners 2 03-08-2004 08:11 AM
2009 InternetBrands, Inc.
