80 amp fuse help
Old 05-13-2009, 12:26 PM
Jory121's Avatar
80 amp fuse help
does anyone know how to get that freakin 80amp out thats in the fuse box under the hood????
Old 05-13-2009, 12:49 PM
Elton's Avatar
its more then likely bolted in from under neath
Old 05-13-2009, 01:14 PM
bugs1961's Avatar
Unbolt the fuse block from the fender so you can access the bottom. Take the bottom cover off and you can see the underside of the 80 amp fuse. The fuse is in a small holder that has a release on top similar to a connector for other electrical components. Push the release and the fuse holder will drop down the bottom of the fuse box and then the bolts that pass through the spades will be accessible. You may be able to get to the bolts without releasing the fuse holder but only from below. Take care,
Bugs
Scotttekoch
09-28-2015 10:30 PM
JPV
09-28-2015 03:15 PM
Rcbc92
09-26-2015 03:00 PM
toyotasaurus
09-24-2015 03:30 PM
Tcsdef
09-07-2015 11:17 PM
Quick Reply: 80 amp fuse help
