7.5 front diff dis-assembly
Is there a diagram or walk through anywhere on the dis-assembly of the 7.5 front diff? I want to rebuild mine since the stub shaft has alot of play but i cant seem to find a diagram anywhere
I just did mine to put some 5.29's in. Zuk was here helping me through it. If you get all the right parts to begin with, it's very doable. You need a press, a dial indicator with a magnetic base, an inch pound torque wrench and you have to make something to hold the pinion flange while you tighten the pinion nut. Make it long, it takes a LOT of torque to crush the crush sleeve.
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
08-04-2015 02:08 PM
yourrealdad
07-29-2015 11:08 AM
Steven.m.paulk
07-24-2015 01:44 PM
scottyg486
07-19-2015 05:34 PM
TokyoD23
07-12-2015 06:01 AM
