63 chevy rear shackle mount
this might have been asked before but is is possible to mount the rear shackle mount of my 63 chevys threw the frame rather than under I don't want to get to much lift no higher than 2" so I want to raise the shackle mount higher to lower the rear but still have the travel ...has any body done this or have any links or pics and measurements would help alot thanks
go to pirate. there a slew of info on their chevy spring swap thread. read it all twice before you post a question. i barely got 2'' of lift on mine, and i used the factory shackles.
I've done the Chevy swap before, It really doesn't lift the truck that much - in the neighborhood of 2-3" best case... If you need less, adjust your shackle angle.
I needed 4-5" lift, ended up extending the shackle, adjusting the angle, and doing an add-a-leaf.
Flying91
45
04-11-2024 04:39 PM
jon.r
07-11-2015 03:34 PM
skoti89
07-08-2015 12:05 AM
