63" Chevy Leaf Springs - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-16-2007, 11:29 AM   #1 (permalink)
corvettelvr73's Avatar
Send a message via AIM to corvettelvr73 Send a message via MSN to corvettelvr73
Question 63" Chevy Leaf Springs
What year Chevys does the 63'' Leaf Springs come off of. Do I have to do any fabrication to get the to fit. Also what is the best way to lift the front end on a 87 4runner.
__________________
95' 4Runnner 3.0 Auto 4x4 (158K) Blown HG Needed new block. SOLD!!!
87' 4Runner 231K (TOTALED)( In The Scrap Yard)
86' 4Runner (In The Scrap Yard)
85' Pickup (Trail Rig & Daily Driver)
80' Pickup (In The Scrap Yard)
www.myspace.com/TRDTundraLVR9
corvettelvr73 is offline
Old 01-16-2007, 11:39 AM   #2 (permalink)
Send a message via AIM to dcg9381
http://www.pirate4x4.com/forum/showt...threadid=20665
Some fabrication is required, yes. Springs are longer so perches have to be welded.
__________________
http://www.22REturbo.net
dcg9381 is offline
Old 01-16-2007, 11:44 AM   #3 (permalink)
Tacoclimber's Avatar
Quote:
Originally Posted by corvettelvr73 View Post
...Also what is the best way to lift the front end on a 87 4runner.
Depends on what you want to do with it, and who you talk to.
If you're gonna crawl it, most say SAS is the only way to go. If you aren't gonna wheel it too hard, an IFS bracket or BJ spacer lift would work. Lotsa info and lots of opinions on the subject in the YT archives...
__________________
CJ ...<><
03 DC TRD Tacoma 4wd with a bunch of junk. SOLD
1964 Chevy Biscayne, 230 I6, lowered, satin black, old-school legit.
Just wheel the stupid thing!!!
But do it responsibly, ok?
My band: Road Worn Saints
Tacoclimber is offline
Old 01-16-2007, 02:01 PM   #4 (permalink)
Bear80's Avatar
Send a message via AIM to Bear80
88-98 1500 2wd springs. 2wd are 3 leafs + over load. HD trucks like the 2500 and up will have 4-6 + over load leaf and 4wd start at 4 leafs and go up to 6 leafs depending on setup. You can use the 99-current springs but might not get the same hight as the older springs. The newer chevy trucks use 2 leafs both 2wd and 4wd plus a block(which is total BS for a manufacture to use). I would guess if you used a 99-up springs you'd need an add-a-leaf or re-arched lift springs or blocks.
Also mount the front hanger 11 1/2" forward and the rear shackle mount 4 1/2" back. All the online info states 11" and 4" but that doesn't work well on the 84-88 trucks/4runners. Pick up a 4* castor shim to correct the pinion angle. Also I found a 7" hole to hole shackle works better than the advertised 6" when a new rear mount it used. If you use the stock rear shackle mount you'll need at least a 9" hole to hole shackle. Just whatever you do DO NOT USE A DOUBLE SHACKLE!
Oh and the 91-98 springs are IMO made better than the 88-90 springs, the newer ones use anti-sweek pads.
__________________
1986 Truck - Monster IFS
1997 FZJ80 - Locked, Lifted, Ready
Range Rover Recovery Vehicle
Bear80 is offline
Old 01-16-2007, 02:07 PM   #5 (permalink)
Bear80's Avatar
I'll show some pictures of my setup, which is still a work in progess, as soon as the weather gets better.
__________________
Bear80 is offline
Old 01-16-2007, 03:23 PM   #6 (permalink)
Dont do it its not worth the headache
__________________
86 SB4x4 all the goodies . ITS TRAIL RATED LOL
lilyota is offline
Old 01-16-2007, 03:36 PM   #7 (permalink)
So are the Chevy springs better or worst and whats the best way to lift the rear is they are worse
__________________
Old 01-16-2007, 03:59 PM   #8 (permalink)
Bear80's Avatar
Quote:
Eh? why have you even done it?? Any other spring upgrades, marlin, trail gear, etc. all require welding at least new forward mounts. IF you can measure and get your axle centered to you liking, there are no headaches with the chevy springs. The swap is very very simple, no headaches. Chevy spring pairs can be had at the junk yard for under $75, new front hangers $45, rear shackle mounts $35, 4* pinion shim $20, shackels $45 and depending on spring/shock mounts a u-bolt flip or just new u-bolts if your re-using the stock mounts like me $40. Where is the headache?? Taking it to my welder and paying him $40 to weld the mounts?? Nope. I say for the gains of globs of wheels travel and a hell-of-a smooth ride it was well worth the little time and money. I actually only paided $40 for my springs at the junk yard so if you do it well, the swap can cost from $225-$300 and replacement springs can be bought over and over for cheap.
__________________
Bear80 is offline
Old 01-17-2007, 02:26 PM   #9 (permalink)
yes I have ran them and they hung up on anything and everything that was on the trail, the only way they flex better is with the dual shackle setup that will unload when you don't want it to, the toyota rears flex just as good with minor modifications.
For a little extra you can buy a complete kit for the rear.
Its not the installation thats the headache that stuff is easy
__________________
lilyota is offline
Old 01-17-2007, 02:31 PM   #10 (permalink)
Also are you trying to get lift or flex
__________________
lilyota is offline
Old 01-17-2007, 02:50 PM   #11 (permalink)
I'm looking for both but mostly lift.
__________________
Old 01-17-2007, 02:54 PM   #12 (permalink)
Bill's Avatar
I've talked to a few guy running them, and they really like them, but there is a general consencus: if you just want lift, it's a bad way.
Most reports I've read(and seen) are that if the springs you get are new, then you will get some lift 1-3" range. But if you're getting old junk yard springs they flex great, but give you little to no lift.
I'm planning on doing this swap myself once my truck is running again.
__________________
86 Turbo Pickup
EB Street RV head
EB 268 Cam
V6 Brakes + MC
A340F auto ---> W56 5-spd swap
...I want a bigger turbo...
Bill is offline
Old 01-17-2007, 03:03 PM   #13 (permalink)
boriswebs's Avatar
Send a message via MSN to boriswebs
When I did it I got new springs. The springs alone give a 2 inch lift. Add some longer shackles and you can get more. I have about 5 inches due to the longer shackles I'm using. Chevy springs give you a better ride and more flex over stock springs. Just read everything on the pirate write-up and you will be-able to get them on in a rather short amount of time.
__________________
VERONICA 91 l X-Cab l SR5 l 3.0 l Auto l 35's l 4 inch Pro-Comp lift l 3 inch body lift l Chevy springs l Custom Air Intake l Custom Rear Bumper l Custom interior l several other mods.
Project Satan 86 Mazda B2000 l Slammed l Tower Notched l Shaved
l Custom Interior, Relocated Gas Tank, Headers, Straight pipes, Flowmaster Super 44, Cam, Webber Carb, Electric Fan, Optima Yellow Top
My yotatech Profile
boriswebs is offline
Tags
16, 63, 81, angle, chevy, correct, inch, leaf, lift, rear, shim, spring, springs, tacoma, toyota, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Chevy 63" rears or Rear Lift Springs and 5.29 gears M threezy The Classifieds GraveYard 1 06-08-2007 08:49 PM
" 63" chevy leaf springs" big johnson The Classifieds GraveYard 1 04-28-2007 06:29 PM
63" chevy leaf springs for sale $50 obo bowtoyclc The Classifieds GraveYard 5 05-12-2006 10:17 PM
Best add-a-leaf for 63" chevy rear springs Adam F Offroad Tech 5 04-10-2006 06:27 PM
63" chevy rear springs on 98 taco? alanbobalan 95.5-2004 Tacomas & 96-2002 4Runners 8 02-28-2006 01:00 PM
2009 InternetBrands, Inc.
