6-7 inch rear lift on ext cab pickup need longer driveshaft?
Old 09-12-2011, 08:29 PM
gary96360's Avatar
hey i was wondering if the driveshaft would bind with a 6 inch rear lift? if so would i have to buy shims. could you lower the carrier bearing by making some brackets? thanks.
Old 09-13-2011, 12:23 AM
Alcan_yota's Avatar
I havent seen any problems with a 5 inch lift causing binding.
Old 09-13-2011, 03:27 AM
rattlewagon's Avatar
Make it a 1 piece shaft.
Thats alot of lift. Why so high?
Old 09-13-2011, 04:12 AM
waskillywabbit's Avatar
Your problem will be length, as in too short.
It's simple Pythagorean geometry.
:wabbit2:
Old 09-13-2011, 01:49 PM
gary96360's Avatar
got bj spacers and add a leaf in the rear, 3 inch body. now going to put in a 4 inch procomp stage 2 lift with blocks. i know the truck is too high for you guys but i dont wheel hardcore like you guys
Old 09-13-2011, 04:55 PM
drmix's Avatar
What size of tires are you gonna run on this thing? Sounds like youll be pushing the limits of the IFS
Old 09-14-2011, 06:10 PM
gary96360's Avatar
im going to lower the front end after lifting it so the angles wont be soo steep
Old 10-04-2011, 08:50 PM
gary96360's Avatar
got an issue. installed the 4 inch bracket lift but the front driveshaft doesnt angle low enough to hook up to the front diff. i took out the diff drop spacers and it still wont work.
6th Gear
19
12-10-2019 07:31 AM
Regency
07-05-2015 08:16 PM
Valvoman
06-28-2015 02:45 PM
94more
06-19-2015 01:55 PM
Old Red 94
06-16-2015 08:32 PM
Quick Reply: 6-7 inch rear lift on ext cab pickup need longer driveshaft?
