5vz head gasket
5vz head gasket
I am in the middle of a 3.0 to 3.4 swap and am replacing head gaskets I called the local parts store and they want like 450 bucks for the kit but I went online and found a set that came with head bolts for 90 whats the deal?
Quality.
Pay the extra money and get the full top end gasket kit from Toyota for $450-500, it has every gasket you'll need. While you're there order new head bolts, they're $16 each (I think) and you'll need 16 of them; those bolts are one time use only.
I ended up buying another 3.4 from a local junk yard rather than replacing the head gasket on my original donor 3.4.
Toy Only Swaps crossover (http://www.toyonlyswaps.com/Page_4.html) to OEM down pipe collector (2->1) then took it to a muffler shop and had a CA legal cat installed with 2 Denso O2 sensors in their relative position to the factory locations.
I'm in California and had to go through the whole SMOG ref inspection and had to follow all the rules to keep all the emissions related components as close to factory as possible.
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
