5speed swap question
Old 03-24-2011, 08:57 PM
justin_4runner's Avatar
so im looking at doing the 5 speed swap this weekend.i have a couple question i need answers for.....
1 i need to know if the bolts from the flex plate and the bolts for the flywheel are the same?
2 also are the bolts that hold on the clutch plate the same as the ones that hold the torch converter?
thanks justin
Old 03-24-2011, 09:14 PM
wyoming9's Avatar
Red face
I think you will have a interesting weekend
Old 03-24-2011, 09:16 PM
Birdbrain's Avatar
Justin
1) I honestly dont remember.
2) No they are different.
I know we had to run to Shmucks last minute and pick up bolts for... something in that general area. Cant recall what though...
You have my number, feel free to hit me up if you have any questions, the girls gonna be gone this weekend, so let me know if you'd like a hand as well
(^ that sounded gayer than I thought...)
Old 03-24-2011, 09:23 PM
srozell's Avatar
I did this so long ago, and I don't remember all the details, however I do remember that the flywheel bolts taken from the automatic are too short for the conversion. Probably about 3/4" of an inch too short.
Old 03-24-2011, 09:24 PM
Birdbrain's Avatar
THATS what it was!!!! I knew it had to do with the flywheel...
Old 03-24-2011, 09:30 PM
srozell's Avatar
Yeah, I woulda run to shmucks too, but it was 2:00 a.m. when we got that far.
Overall, I would say the job went really smooth though.
Old 03-24-2011, 09:34 PM
guess i will be calling toyota to see how much and if they have them in stock and the sizes and that for the bolts to make sure i have them for sat... and matt if u want to get out of the house and drive down help would be great.
Old 03-24-2011, 09:41 PM
Birdbrain's Avatar
Why does that sound familiar...
They will rape you, shmucks had em for like 5 bucks?
Sure man, just gimme a call!
Old 03-25-2011, 07:27 AM
2DoorRunner's Avatar
Any parts store should carry some flywheel bolts. They were like 10 bucks for a set for my 4.3.
Some grade 8 bolts would probably be fine too, its not like your running crazy power or anything. But get the right ones if you can.
Same with pressure plate bolts, grade8 and call it good.
Old 03-25-2011, 12:42 PM
Birdbrain's Avatar
For th M/T rear driveline length..
Measure from this point:
to this point:
i got 42.5"
I want to say the automatic is like, 39.5 give or take.
-Matt
Old 03-25-2011, 12:49 PM
thanks man..
Old 03-25-2011, 12:50 PM
Birdbrain's Avatar
thanks man..
np! let me know if theres anything else you need man.
Old 03-28-2011, 10:54 AM
so the 5 speed is in and running, drove it to work today and the rpm at 60 where at 2650 to 2750 and at 70 at 2850 to 3000 so not too bad for gearing wise, now i just need to get some 33s and put under it,
Old 03-30-2011, 02:41 PM
just thought i would put how much i payed for each item just to give people an idea of how much this swap cost.
1. trans and slave cly. 100.
2. pedals 10.
3. master 5.
4. hard and soft lines 5.
5. shift boot 5.
6. fly wheel 60.
7. clutch 140.
8. flywheel and clutch bolts 15.
9. rear drive shaft 30.
10 speed sensor 20.
just to get an idea... total 400.00
Old 10-05-2011, 06:49 PM
black914runner's Avatar
cant seem to get mine started cant figure out what wire i need to ground to make it think its in park. do u remember what one it was my truck is a 94 4runner thanks
Old 10-05-2011, 11:15 PM
wyoming9's Avatar
Smile
You need to jumper the neutral safety switch.
You don`t want to ground it.
coleypull15
11-03-2015 07:41 AM
deepmarsh
08-06-2015 03:44 AM
KBar
07-13-2015 06:01 PM
Coreyr384
07-10-2015 11:13 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 5speed swap question
