YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-29-2008, 08:00 PM   #1 (permalink)
SR5
SR5's Avatar
$532 = 4"
Front OME Shock
Rear OME Shock
Rear OME Lift Coil Spring
Front OME Steering Dampener
provides 2"
http://www.rocky-road.com/4runner.html
1 Pair 2"/50mm Coil Spring Spacers and
1 Pair 1.5"/38mm Ball Joint Spacers
provides the other 2"
also
Panhard Rod Drop Bracket
http://www.4crawler.com/4x4/ForSale/...anhardDropBrkt
What do you guys think?
good combo?
anybody running this?
__________________
1995 SR5 V6 4Runner
SR5 Profile
|31x10.50 BFG All Terrain|Diff Breather Front, Rear|Low Profile bump stops|Blue LED Dash|Japan Running Lights|Alpine Deck|Custom 6.25 Sony 4 Way Rear Speakers|4" Alpine Front Speakers|
SR5 is offline
Sponsored Links
To remove this ad, register today!
Old 08-29-2008, 08:21 PM   #2 (permalink)
Matt16's Avatar
You cannot lift the front 4.5" without a bracket lift. The front is actually best left stock height for durability. Buy lockers and forget the lift, 4Runners already have more ground clearance than just about any other 4x4 stock.
__________________
1990 Toyota 4Runner 22RE 5spd
Rear Aussie Locker [click here for the review] *Nokian Vativa A/T tires* OME suspension* York OBA* pretty much stock.
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Toyota FAQ link
More info on 4Runners
- awesome resources
Matt16 is offline
Old 08-29-2008, 10:29 PM   #3 (permalink)
SR5
SR5's Avatar
Well when i first bought the truck i would have agreed with you, i couldn't find a place to get stuck, but as time moved and as i got more serious into wealing well the need for a lift become clear
__________________
1995 SR5 V6 4Runner
SR5 Profile
SR5 is offline
Old 08-29-2008, 10:54 PM   #4 (permalink)
SR5
SR5's Avatar
wait is the reason that you cant lift the front 4.5 inches because the A arms would be to over extended??
__________________
1995 SR5 V6 4Runner
SR5 Profile
SR5 is offline
Old 08-29-2008, 11:22 PM   #5 (permalink)
abecedarian's Avatar
I'm stuck with the math...
nothing other than the BJ spacers changes the front lift.
so... BJ spacers= 1.5" lift up front....
someone want to explain how we end up with 4.5"?
even with 1" from a torsion bar (not listed in the OP, but is on the webpage about the lift)...
we're still at 2.5, not 4.5
even when combining the best of components from the original post,
I still can't get any more than 3" no matter how I try to stretch it.
__________________
Quote:
Originally Posted by Obama 'Ironman' Hussein
I want to ensure that everyone has the same capabilities off-road. Whether from the factory through high-dollar investments, from the aftermarket or by the hard work of the American backyard mechanic.
Therefore, I am taking some suspension travel from the more capable, more invested, more costly vehicles and transferring ... no ... redistributing that suspension travel to the other less fortunate vehicles. I am doing so in order to guarantee that everyone has the same opportunities off road.
abecedarian is offline
Old 08-29-2008, 11:26 PM   #6 (permalink)
Quote:
how about this: you can't lift it 4.5" because it's not in the kit(s) you're looking at.
and going 4.5" lift with an IFS suspension would bind the CV joints unless the differential was lowered, and that's not in your 'kit' either.
__________________
Old 08-30-2008, 12:01 AM   #7 (permalink)
SR5
SR5's Avatar
well the new shocks up front raise it 2"
at least thats what OME site said
__________________
1995 SR5 V6 4Runner
SR5 Profile
SR5 is offline
Old 08-30-2008, 12:12 AM   #8 (permalink)
CC_yota's Avatar
Send a message via Yahoo to CC_yota
__________________
95 4Runner- 3vze- A/T- 4.88's
Currently
LC Coils
BJ Spacers
SAW T-Bars
32x11.50 BFG A/T's
15x8 black Rockcrawlers
Marlin Crawler rear bumper
CC_yota is offline
Old 08-30-2008, 12:51 AM   #9 (permalink)
Jeenyus04's Avatar
shocks them selves cannot raise a vehicle
if your starting to do some serious wheeling thinking about an sas may be a better idea than fighting with your ifs for a while then giving in and doing it.
__________________
85 reg cab s/b, rebuilt 22r, .040 over bore, engnbldr's crawler cam, no cat w/ flo-pro (was on it). tg 5 inch lift. 35 baja claws bright green paint, sliders, custom front bumper, miller rear locker --project--
02 dodge extended cab s/b, black sport, 24 vavle cummins, 35's, 4 inch exhaust, edge ez
Jeenyus04 is offline
Old 08-30-2008, 06:27 AM   #10 (permalink)
Ok, let's start way at the beginning.
Why or what, specifically is causing "the need for a lift become clear" ??
To provide meaningful help, we need to know what the specific problem(s) is(are).
Fred
FredTJ is offline
Old 08-30-2008, 06:28 AM   #11 (permalink)
No, that's not what the site says.
You didn't read it close enough
Fred
FredTJ is offline
Old 09-01-2008, 05:33 PM   #12 (permalink)
SR5
SR5's Avatar
Fred
the site said 2" and all that came on the front was shocks so i assumed that whats lifted it
the need for a lift comes from
A) Height clearance of the belly
B) the need to fit 33 and still have flex
C) to have more range of motion of my sespention
__________________
1995 SR5 V6 4Runner
SR5 Profile
SR5 is offline
Old 09-01-2008, 06:04 PM   #13 (permalink)
I think I know where the confusion lies. The site says that if you're not installing the oversize torsion bars that you'll have to adjust the stock bars for the lift. Either option is not the smartest thing to do if you're planning on using 4wd- cranking the stock bars for lift will put your CV's in a position to bind and also give you a more harsh ride since you'll have almost full suspension travel for compression and almost none for extension and the installing the uprated bars may give you a stiffer ride and will also require you crank them for lift so you'll have the same problems as using the stock bars.
Also, you won't get any extra flex at all in the front unless you install the BJ spacers.
__________________
Old 09-01-2008, 07:02 PM   #14 (permalink)
The 2" should mean for 2" of lift with regard to the shocks, as in what they can accomodate. I would get the coil spacers, bj spacers and a 2" Body lift if I were you.
Mic09dcsm is offline
Old 09-01-2008, 08:06 PM   #15 (permalink)
ovrrdrive's Avatar
Going with oversized tbars and cranking them up and adding bj spacers both give the same type of lift and both are going to put your cv's in a bad angle. Trying to do both at the same time will make the truck all but un-drivable. If you want/need 4" you need to go with a bracket lift. You can get a 4" Rough Country bracket lift for $599 shipped direct and it is the same lift as a Superlift but with different coatings on the parts.
Thinking that you have to somehow justify why you want to lift the truck on here before you get any advice is just plain silly...
__________________
'95 xcab 4x4 22re,3" BL, 4" Superlift, 1.5" BJ Spacers, 36x13.5 Iroks, M/T Classic Locks, 5.29's, Rear Lockright, J and C head with engnbldr O/S SS valves, RV springs, and Crane Stage 2 cam, Magnaflow 14" with 2.25" in and 2.5" out, NGK V-Power BPR6EY's, OBA with Viair 380C and a 3 gallon tank @ 180psi, Siege Engineering Train horns - Truck bought new in Dec. '94...
My buildup thread: link
'03 4runner V8 SR5 completely stock
ovrrdrive is offline
Old 09-01-2008, 08:21 PM   #16 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
Well, cranking the torsion bars usually causes you to ride on the upper bumpstops = very little down travel. This usually causes a rough ride. BJ spacers allow for the lift but also increase your up travel while keeping your downtravel stock. Verrr nice!
Yes, incase you have not got the just of it yet - shocks do NOT provide lift. When they say they are good for 2" of lift, that means they will fit a truck lifted 2".
You cannot do any lifting beyond around 2" without droping the differential. Without a diff drop your cv joints are not able to cope with the angle.
Do some research
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic
http://www.cardomain.com/ride/2572486
Jay351 is offline
Old 09-01-2008, 09:48 PM   #17 (permalink)
SR5
SR5's Avatar
Quote:
i checked but they dont have one available for my year
__________________
1995 SR5 V6 4Runner
SR5 Profile
SR5 is offline
Old 09-01-2008, 10:07 PM   #18 (permalink)
Fizboy's Avatar
If you are wanting to put your rig on 33's you should be able to do it with little to no lift at all in the front with minimal rubbing. I run 33X10.50 on mine with little rub on the sway bars. I do have the thicker torsion bars but that is because I plan on putting on a heavy bumper.
__________________
92 4-RUNNER AKA: "THE MEXICAN TAXI"
33x10.50-15, Downey 26mm torsion bars, Downey 3" kit sitting on All Pro 1 1/2" coils, HyperFlex suspension bushing kit, flex-a-lite electric fan, NWOR hedders, Flowmaster, K&N, silencer mod, Yakima roof rack w/ Surco safari basket, Midland 75-822 hand held CB, and a bunch of other mods.
84 PU THE EXTREME BUDGET VEHICLE
Project Seven Rocks
63" Chevy swap, 4X innovations horse collar, 31X10.5 Interco TrXus MT. Slow go cause I am broke.
Fizboy is offline
Old 09-01-2008, 10:53 PM   #19 (permalink)
huh? who doesn't have it? rocky road?
they are made you just have to find em.
__________________
Old 09-02-2008, 05:10 AM   #20 (permalink)
ovrrdrive's Avatar
