5 speed swap on a 87 runner~
Old 08-18-2009, 08:48 PM
94toy4x4fever's Avatar
Well this past weekend I started my swap! It took me almost a week to get all the little stuff for this swap, but now I have everthing I need! I got my old tranny about half way out and I have a few questions! How do I get the tourq converter bolts off? Do I get them out threw the starter hole? Also how do I get the piolet bushing out of the back of the engine? Other than that everthing is going well! I will post up some pics here soon! Any help would be great! Oh and one more question how do i make sure and get the hole in the floor board right for the shifter to come threw? Hey Im a new to this swap stuff but i like learning as I go!
Old 08-18-2009, 09:02 PM
881stGenRunner's Avatar
The torque converter bolts should be in the center of the torque converter, just have a friend hold the engine from spinning in the front and take off the bolts. To get the pilot bushing out, check out a thread that iamsuperbleeder created about getting it out, it has a very good video in it that shows step by step instructions.
To get the hole right, just lay down the new shifter boot holder and draw a line around it then when you do your cut make the cut about a 1/2" inside of that line you just drew in the sheet metal. Thats what we did when we did my swap last year.
Old 08-18-2009, 09:09 PM
How do i get to the torque converter bolts thought? Also do I hold my shifter boot holder kinda in the center of the old auto holes or hold the top of the boot holder to the top of my old tranny hole!
Old 08-18-2009, 09:17 PM
Hey that video is BA! Very cool idea
Old 08-18-2009, 09:20 PM
ok hold on! So I dont have to pull the torque converter bols out first before I pull the tranny? I have pulled a few trannys before but not a toyota auto!
Old 08-18-2009, 09:24 PM
nope, go ahead and drop the tranny then the TC will still be up in there and it may just slide out, i cant remember, but im PRETTY sure there are bolts holding it on.
Old 08-18-2009, 11:39 PM
85TurboRunner's Avatar
the torque converter is bolted to the flex plate, you will need to unbolt it through the starter hole.
Old 08-19-2009, 05:20 AM
ok! Anyone one else have a good Idea for cutting the hole for shifters?
Old 08-26-2009, 12:59 PM
eric1115's Avatar
I put the trans in, stuffed/covered the hole in the top very thoroughly, peeled the carpet back, and used a cut-off wheel on an angle grinder. Pretty? Maybe not... but I got the holes where the trans wants the levers to be, and not where the boot thinks it wants to be.
Old 08-29-2009, 01:13 PM
I just put my boots down were it covered the hole ok and used 4 self tapping skrews to hold it in place! Work great for me!
Old 08-29-2009, 01:16 PM
what oil to use in a 1994 toyot 5 speed?
What is the best oil to use for this tranny? Also what size socket is the drain plug? Oh and the fill/drain plug on the transfer case?
Old 08-29-2009, 04:25 PM
Check what your owners manual says, but im pretty sure its GL4 in both tranny and xcase. the plugs should be 24MM
Old 08-29-2009, 09:23 PM
in other words 75-90 or 80-90 I think im going to run the 75-90 because it dosent get to cold here!
B. Graves
07-03-2015 04:10 AM
Valvoman
06-28-2015 02:45 PM
ACZR
06-23-2015 07:55 PM
Mr.Black
06-21-2015 10:17 AM
TheManOutside
06-18-2015 03:32 PM
Quick Reply: 5 speed swap on a 87 runner~
