#5 sparkplug on 3.slow ???
OK, there is probably posts buried deep within the forum....anyone have a link or tricks to get at this plug (rear passenger side) got them all done but this one.
Its tight, but doable.
Long extension and a wobble adapter. To re-install use a peice of rubber hose just big enough to slip over the end of the plug. This way you will have a harder time crossthreading it. (an old mech did that to my number 6 plug).
What plugs are you using (gapped to 0.030" right?)
NGK's with anti-seize gaped to .032.
Gotta say the old plugs have been a bear to get free. Went slow kept even pressure.
I guess I have big mitts/arms cause I can't get a decent grip on #5 to pull the wire. I'll take a break from it and revisit it later
I don't see what is so hard about this? I changed my plugs on the 3.0 for the first time & it only took me about 15-20 minutes. I used a 1/2 drive ratchet along with a 3" & 6" extension & a wobble. It was very easy & straight forward. The piece of hose will help you to get them back in as that was the only tricky part.
39 Thieves
01-06-2017 01:08 PM
Peevedkitten
11
08-31-2015 06:57 PM
