4X4 noise
Old 07-16-2008, 07:43 PM
90-4runnerv6's Avatar
4X4 noise
Hi again,
Well I got my 1990 V6 4runner back. It seems to run fine which is a big woohoo!
A new problem (doesn't seem to end) is that when I engage into 4wd there is a distinct clicking noise when I turn the steering wheel in either direction. Is this normal? What could it be if not normal?
Thanks!
Old 07-16-2008, 07:49 PM
TOYOTA 1's Avatar
it should click when it engages, but after that it shouldn't make any noise.
Old 07-16-2008, 07:53 PM
The clicking noise is continuous. It doesn't click if I am going straight, but if I turn especially if it's a sharp turn then there is clicking.
Old 07-16-2008, 07:55 PM
TOYOTA 1's Avatar
sounds like its your cv axles.. although ive never heard mine click, only break lol..
Old 07-16-2008, 07:58 PM
Damn. The dealership just replaced the CV boots. They didn't mention anything about the axles being in poor condition. I just spent $640 on the CV boots.
Old 07-16-2008, 08:00 PM
TOYOTA 1's Avatar
huh??? $640 on cv boots?
Old 07-16-2008, 08:02 PM
TOYOTA 1's Avatar
heres a whole new cv, with new boots for under $100
http://cgi.ebay.com/ebaymotors/CV-AX...spagenameZWD1V
Old 07-16-2008, 08:04 PM
Just wanted to clarify, but the clicking noise only happens in 4wd and only when turning either direction. Would the ADD system make a clicking or ratcheting noise when turning as a normal sound?
Old 07-16-2008, 08:08 PM
TOYOTA 1's Avatar
hmm. i wouldnt think so, but ive always had hubs. are you shure you dont have a locker in there? hehe.
Old 07-16-2008, 08:10 PM
Well it does says ADD on the front.
This is my first 4wd vehicle and so I'm not sure about all the noises and whatnot I should expect to be normal and not normal.
Old 07-16-2008, 08:12 PM
TOYOTA 1's Avatar
i understand, maybe someone with an add system will chime in with some info.
Old 07-16-2008, 08:14 PM
GSGALLANT's Avatar
You have a part time 4WD system, which means you shouldn't be driving in 4WD unless you are on slippery surfaces (sand, dirt, ice, snow). If you drive in 4WD say on dry pavement and you turn the steering wheel, you will get binding in your drivetrain caused by the front wheels following a longer path than the rear wheels (so your front wheels want to turn faster than your rear wheels, but they can't because you don't have a center differential in your 4Runner).
Do this too much and eventually you will break something.
Old 07-16-2008, 08:15 PM
Jay351's Avatar
Nope, the ADD system is very quiet. There is the initial click when it first goes in or out of 4wd. A constant clicking when turning in 4wd is usually cv-joints on their way out. Sorry to say....
Old 07-16-2008, 08:22 PM
So please excuse my newbie ignorance, but when then should I engage in 4WD. I bought this 4runner because I have to a property that has dirt roads. Some of the dirt roads are steep and has deep ruts and loose dirt/gravel along with the occasional large rock or two. I know the person who showed us the property always engaged his 4wd in his Tahoe and I never heard any clicking noises.
Would this situation not be a time to use 4wd?
Thanks again from a newbie.
Old 07-16-2008, 08:25 PM
TOYOTA 1's Avatar
that would be a perfect time.. you just dont want to go turning real sharp on dry pavement in 4wheel drive.
Old 07-16-2008, 09:06 PM
Jay351's Avatar
If the surface you are driving on is slippery enough to allow the front wheels to slip to keep up with driveline bind you will be fine. I have used 4wd on dry pavement before, its not a great thing but its not horrible for your ride.
LIke I said before, the clicking, if its a constant noise while turning, almost always points to bad cv joints. Usually if the boots are torn, they will fling all the grease out and wear out the joint.
Old 07-16-2008, 10:07 PM
874runnersr5's Avatar
hey Toyota1, would you recommend those ebay cv's?
Old 07-17-2008, 03:10 PM
TOYOTA 1's Avatar
ive never bought one from them! so i have no info on them.
i was just surprised at the cost of those cv boots the op had bought.
so i just found a link to show him how much cheaper he could get them.
but i have had good experiance with cv's from napa and carquest.
there about the same price as the e-bay one's. and they work just fine!
Old 07-17-2008, 03:22 PM
SEAIRESCUE's Avatar
You mention "new problem" so take it back to the thieves at the stealership and tell them to fix what they should have fixed when the boots were replaced. Wanton negligence in my opinion.
My $0.02
mskalmus
05-28-2017 07:51 AM
coleypull15
11-03-2015 07:41 AM
PlayAwhile
07-20-2015 11:36 AM
razorman8669
07-12-2015 12:13 PM
Jonny246
07-12-2015 04:51 AM
Quick Reply: 4X4 noise
