4wd problem
Old 09-08-2013, 12:39 PM
deerslayer126's Avatar
4wd problem
My 1995 toyota pickup 4wd is not engaging. The axels spin all the way to the wheels but the wheels won't spin. Anybody know what could be causing this?
Old 09-08-2013, 12:58 PM
Stetson_md's Avatar
Sounds like the hubs ain't workin,or they aren't locked in
Old 09-08-2013, 01:05 PM
vasinvictor's Avatar
Do you have manual locking hubs or ADD flanges? Does your 4x4 dash light come on? But yeah, what this guy said ^
Old 09-08-2013, 01:13 PM
The light on the dash lights up and I have manual hubs
Old 09-08-2013, 01:32 PM
Are the hubs locked? Had to ask...
Stetson_md's Avatar
Your hubs are probably stove up inside
Wouldn't hurt to rebuild them
https://www.yotatech.com/forums/f116...ild-up-158644/
Old 09-08-2013, 01:55 PM
Hubs are locked in and that's what I was thinking to clean em out make sure they're not sticking
Old 09-08-2013, 02:05 PM
Stetson_md's Avatar
Count the splines while ya got it apart to make sure a previous owner didn't put the wrong hubs on it. Unless you've had the 4x4 working in the past
Old 09-08-2013, 02:29 PM
It worked in the past, do they sell a rebuild kit
Old 09-08-2013, 02:33 PM
Dan Carey's Avatar
You might try warming up the hubs with a hair dryer of if you're handy use a propane torch. Just don't melt anything.
Old 09-08-2013, 03:15 PM
Cyberman's Avatar
No "kit" really needed, except some gaskets.
Toyota Maintenance: Servicing the Aisin Manual Hubs
Aisin Manual Hubs
Old 09-08-2013, 03:18 PM
Stetson_md's Avatar
They may sell a rebuild kit im not really sure but low range off road sells upgraded versions of just abo ut every peice in the hub in case you need to replace somthing that's broke
djpg2000
11-11-2020 04:56 AM
mskalmus
05-28-2017 07:51 AM
adammtb
07-27-2015 11:57 AM
jgwerth
07-16-2015 03:23 PM
TokyoD23
07-12-2015 06:01 AM
Quick Reply: 4wd problem
