4wd power steering vs. 2wd
Old 11-20-2008, 09:54 PM
lotalucas's Avatar
I have a 1990 4wd pickup with a 22re. If i got a used power steering pump and box from a junk yard would it matter if i got it off a 2wd truck instead of a 4wd or do i need to get it off of a 4wd. There are never any 4wd trucks at the junk yard.
Old 11-20-2008, 10:12 PM
abecedarian's Avatar
should be the same pump.
steering box looks the same between my 88 4runner (4wd) and my 91 pickup (2wd)
idler arms look different though.
Old 11-20-2008, 11:26 PM
JamesD's Avatar
The steering boxes are not the same. Everything else should be the same.
James
Old 11-20-2008, 11:36 PM
James
not trying to be difficult or argumentative...
but what is different with regards to the steering box?
Old 11-21-2008, 06:43 AM
JamesD's Avatar
The pitman arm shaft in the gearbox itself is longer on the 4wd.
4WD
2WD
Old 11-21-2008, 08:59 AM
lotalucas's Avatar
cool. that's what i needed to know. I was gonna by them new but that would cost way to much.
Old 11-21-2008, 11:29 AM
Jay351's Avatar
I will agree that the pump works. Im running one from a 1993 2wd.
Old 11-21-2008, 01:55 PM
JamesD's Avatar
Really? What is the difference? The height of the u-joint going into the gearbox?
James
Old 11-21-2008, 03:42 PM
Jay351's Avatar
Im not sure if the gearbox itself transfers over. I just replaced the pump that is bolted to the block. That part swapped over no problem.
Old 11-21-2008, 03:45 PM
JamesD's Avatar
I'm sorry, I misread your post.
James
adammtb
07-27-2015 11:57 AM
colasurdo
07-16-2015 11:32 AM
TokyoD23
07-12-2015 06:01 AM
msane99
07-11-2015 08:08 PM
jon.r
07-11-2015 03:34 PM
Quick Reply: 4wd power steering vs. 2wd
