4WD only engages when cold!!!
Old 12-13-2009, 01:18 PM
CodyJ's Avatar
Unhappy 4WD only engages when cold!!!
This is getting frustrating!
96 T100 V6 5spd with the ADD 4WD
Last winter I had no problems with the 4wd engaging at any time. This year, 4wd only engages when everything is cold. maybe for the first 15 minutes after startup. after that, the dash light wont come on, and the 4wd wont engage. I have to completely let the truck cool down for it to engage again. for example, after a 45 minute drive, and an hour parked in below freezing temperatures, no luck! overnight or 8 hours during work, and it goes right into 4wd.
Any ideas? I have searched, but only found total failures, not just intermittent problems.
Thanks in advance!
-Cody
Old 12-09-2010, 04:37 PM
BrettAk's Avatar
Did you ever get this problem solved?
I am having the same issue with my 96 4Runner SR5. You can engage 4WD no problem when the engine (and everything else) is cold, but if you try to engage 4WD after driving for 10+ minutes, it won't go.
After everything cools off after a couple of hours parked, 4WD will engage no problem at startup.
Old 12-09-2010, 04:45 PM
CodyJ's Avatar
Yea, I replaced the VSV's for the ADD system. I found a scan of the service manual that tells you how to diagnose this, and changed around the vacuum lines as a temporary fix before I found them...
let me see if i still have the scan saved...
-Cody
Old 12-09-2010, 04:52 PM
CodyJ's Avatar
I found the place I got the scans... I dont have them saved anymore, but pay close attention to the written instructions on diagnosing it... helped me a lot.
http://forum.ih8mud.com/95-gen-toyot...-problems.html
Good luck, hope that helped
-Cody
Old 07-29-2011, 05:13 PM
BrettAk's Avatar
Hi Cody. I am just getting around to this, and I believe my VSV's for the ADD system need to be replaced, as well. I see used VSV's on eBay for $40. Where did you get your's and do you think that this is a safe and fair price route to go?
I haven't checked the part number, but the ones on eBay say for 1989-95 trucks, but they look identical to the 96 VSV's.
Thanks again for your help.
Brett
Jayboy74
10
12-21-2021 08:27 AM
Lcb98toy
11
08-26-2015 05:28 PM
norcal98
08-10-2015 06:20 AM
tomczaksdiesel
07-26-2015 10:35 PM
jgwerth
07-16-2015 03:23 PM
Quick Reply: 4WD only engages when cold!!!
