4wd not working
Old 01-26-2008, 07:06 PM
ddc_5114's Avatar
4wd not working
92 4runner manual tranny. Recently purchased truck, 4x4 not working.
replaced add hubs w/warn manuals. Hubs lock but no power is going to the front drive axles. front driveshaft spins transfer case works no unusual noise. 4wd light does not illuminate but I can hear it clicking when i shift in and out of 4wd. Anyone know what my problem is??w/ the manual locking hubs none of the vacuums or actuator could cause this right??
Old 01-26-2008, 07:27 PM
80W90's Avatar
did you verify the operation of the hubs? (locking it, and hand turning the axle?)
next to do is manually actuate the add servo
Old 01-26-2008, 07:31 PM
ddc_5114's Avatar
yes I tested the hubs. Everythings a go! How do I manually actuate the add servo??
Old 01-26-2008, 08:02 PM
just a 22re's Avatar
i think its a vac line on there not sure were or anything but do think its a vac line as i have a 87 hope this helps
Old 01-26-2008, 08:48 PM
Staff
DeathCougar's Avatar
Since you didn't eliminate ADD, i would be looing to the ADD actuator, or the VSV's that control it.
You can run vacuum pressure to one of the two vacuum lines (cant remember which one it is) which will lock the ADd collar in permanetly.
the other way to do it is remove the actuator and jackshaft assy, and replace it with a non-add jack shaft. (or just replace the whole diff if you can find it cheap)
Old 01-26-2008, 09:13 PM
ddc_5114's Avatar
thanks for the advice fellas. will try actuating the actuator 2morrow. youve been a big help!!
Old 01-26-2008, 10:23 PM
RobD's Avatar
http://toyota.off-road.com/toyota/Ax...tegoryId=11290
Old 01-27-2008, 05:32 PM
ddc_5114's Avatar
Fixed it ..had a bad vac line and a few misplaced lines as well..now it works like a champ...thanks for the advice and links...you guys know your stuff.
Old 01-28-2008, 01:42 PM
we try man we try
ashersullivan88yota
01-18-2022 05:37 PM
mskalmus
05-28-2017 07:51 AM
Road Bull
10-10-2015 04:55 PM
cyclist231
07-07-2015 12:56 PM
Suprarossa
07-06-2015 05:21 AM
Quick Reply: 4wd not working
