4wd help
Old Oct 10, 2006 | 07:39 PM
bmnut2002's Avatar
4wd help
My 93 3.0l 4runner will not go into 4wd The gear selector will go, and I hear the relay clicking under the driver's side dash. I checked all of the vaccum lines on the passenger side under the hood, the cannister in the pass. ft. fenderwell. i cheched the vaccum lines to the ft diff., and the electrical connectors on the transfer case. Any ideas? Thanks for the help.
Old Oct 11, 2006 | 02:40 AM
TNRabbit's Avatar
How do you know it isn't in 4WD? Is the light not showing or have you put it on blocks or slippery conditions & checked?
Old Oct 11, 2006 | 04:21 AM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
when you shift in, try going in reverse a little and forward a little a few times to try to get it to click in
Old Oct 11, 2006 | 10:50 AM
bmnut2002's Avatar
Well the light does not light up in 4wd and only the rears spin. I have had no trouble getting into 4hi or 4low with the gear selector. I am thinking it is a vaccum or electrical issue, but have followed all the vaccum hoses and identified them and also verified that all connectors were connected to ft diff. and t-case. Also I can hear the relay clicking. Any advice on electrical diagnosis?
Old Oct 11, 2006 | 11:09 AM
da_bigg_wigg's Avatar
I'd say double check the vacuum hoses. If that fails, check to see if the 4wd sensor in the transfer case is actually working. Test it with a multimeter. This is what was wrong with my 4wd. As soon as I replaced it my 4wd was back in business. It's the sensor on the passenger side of the transfer case, kinda higher up a little. I remember getting at it was a pain in the arse. Just check the connection with it in the vehicle. I can't remember how much the stealer charged me for a new one though...
kawazx636
Oct 6, 2021 03:03 PM
Daenerysdad
Oct 1, 2015 07:33 PM
tylermx71
Sep 29, 2015 08:49 PM
Cycles
Sep 29, 2015 06:37 AM
May-39
Sep 6, 2015 01:05 PM
