4wd after trans swap
Old 04-01-2011, 09:36 PM
justin_4runner's Avatar
so i just swapped out my auto for a 5 speed and im trying to get the 4wd working now, i know that most people will just switch vacuum lines and put in manual hubs, but i was thinking it would be nice to still use the add system and be able to put it in 4hi or lo and go and not have to get out and switch my hubs, i know i have seen someone that did a vacuum set up inside the cab too but i want to see if i can just do it with the system thats there with by passing and jumping where i need,
im thinking i might need to just rewire it all my way to get it to work but just wanted to see what people have to say.....
Old 04-02-2011, 05:02 PM
so after reading over the wireing many times and going what the hel..... i figured it out, i now got the stock 4wd to work with shifting the 4wd lever... heres what u had to do.
first cut harness from the trans u will need it to plug into the trans.
then take the orange and tan wire from the gray harness and splice them together.
now with the black one
the red and blue get put together and yup to one side of the switch for transfer case and the tan wire goes to the other side.
this will then make your 4wd work like it should when u shift it into 4wd hi or lo it will go...
The following users liked this post:
Michael Hampton (12-02-2019)
Old 10-05-2011, 06:58 PM
black914runner's Avatar
i got a few questions in pic one what are the wires connected and why? and then the red and blue get wired into one side of the transfer case plug and the tan goes to the other side?
Old 02-13-2012, 07:03 PM
Fierce Legend's Avatar
Grey plug take orange and gray and put them together. Check
Black plug. Take blue and red put them together. So what are you talking about one side of the TC switch?
I wish you didnt tape everything up
Old 02-13-2012, 07:28 PM
with the blue and red together go to one side of the switch on the transfer case and the other wire on the transfer case goes to the tan wire, but this is if u are going to use the auto ecu.
Old 10-14-2020, 01:01 PM
Junior Sanchez's Avatar
Wiring
Hey sorry to bring this thread back i was just wondering what did you do to connect the reverse gear signal what wires did you connect thank you
mskalmus
05-28-2017 07:51 AM
keithporter83
07-24-2015 07:37 AM
tobylab
Diesel Swaps
07-17-2015 06:51 PM
KBar
07-13-2015 06:01 PM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: 4wd after trans swap
