4runner won't start
Old 04-15-2009, 04:08 PM
huntnfreak's Avatar
4runner won't start
I need some help. I put a new sub and amp in my 4runner last night and it won't start. There is power to everything else but nothing happens when iturn the key. The alarm went off when opened the door and i don't have the key fob, so went to start the truck and thats when nothing happened. since then i have reset the alarm and it still won't start help please.
Old 04-15-2009, 04:23 PM
Jewels's Avatar
i know it sounds stupid and too simple, but check your battery terminals. make sure they're clean and have good contact. my last rig would do the same thing.
Old 04-15-2009, 04:47 PM
huntnfreak's Avatar
i have and the fuses. Is there any way i could of fried the starter
Old 04-15-2009, 04:57 PM
Jewels's Avatar
do you have check lights coming on when you turn on the ignition? if so, sounds like it could be your starter relay. if you have a test light and extra set of hands, stab the tester into the smaller wire coming from the starter with the other end on a good ground, then have someone try to turn it over. if you get power (tester lights up) then relay is good so check wires to starter making sure they're clean with good conection. if still nothing, then drop the starter and take it to auto zone or what not.
Old 04-15-2009, 05:05 PM
huntnfreak's Avatar
what if the light does not light up
and where is the starter relay located.
Old 04-15-2009, 05:19 PM
Jewels's Avatar
the starter relay is on the passenger side bolted to the inside of the fender above the wheel well.
if it doesnt light up the first time, then test the wire that goes to the relay to the ignition.
Old 04-15-2009, 08:46 PM
huntnfreak's Avatar
i will test it thank you i hope i figure this problem out/
Old 04-16-2009, 04:42 AM
huntnfreak's Avatar
I still can not find the starter relay all i found was the bas relay.
Old 04-16-2009, 06:58 AM
PlugItIn's Avatar
is it clicking when you try to stat it, or is nothing at all happening?
Crazychris1871
06-27-2016 10:38 AM
Sandman
07-23-2015 08:15 PM
aciorba23
06-29-2015 04:18 PM
newzingo
06-24-2015 01:50 PM
Corey
06-10-2002 04:23 AM
Quick Reply: 4runner won't start
