4runner roll bar in a pickup?
Old 11-13-2008, 08:49 AM
Junkers88's Avatar
The local pick n pull place has a few mid to late 80's 4runners and the roll bars are only 20$ so I was thinking of mounting one in the back of my 86 ext cab truck. I can't seem to find any pictures of how they mount and haven't had time to hit the pick n pull yet, I could see the runners from the highway. Does the roll bar just mount to the tops of the inner fenders and the rear of the bed floor? Does anyone have pictures of this? I just thought it would be some added strength under my camper top (when I put it back on) in case of a roll-over.
Thanks bunches.
Old 11-13-2008, 09:39 AM
Matt16's Avatar
What about adding a anti roll bar (sway bar) and making discos for them. That's probably what I'd do if I were putting a camper in the bed.
Old 11-13-2008, 09:43 AM
yotasavg's Avatar
What is going on in these pics matt???
OP- ya you could definitely mount one in your bed. at twenty bucks, i want one too! not sure on the mounting but i think all the legs mount to the floor.
i would get that roll bar
Old 11-13-2008, 09:46 AM
Matt16's Avatar
I was thinking anti roll bar. Its been a long night, of the studying kind.
Old 11-13-2008, 10:01 AM
BigBluePile's Avatar
I think this is the tread with what you are looking for:
https://www.yotatech.com/forums/f116...-no-no-158802/
Unfortunately, my work computers ban photobucket so I can't see the pics. It it is, should be able to ask how he mounted the bar.
Old 11-13-2008, 10:17 AM
space-junk's Avatar
dude, junker, pick me one up and figure out what the shipping would be... or let me know how much they weigh... 1st gen roll bars around here are worth a small fortune, and ive always wanted one in my 2nd gen runner...
Old 11-13-2008, 10:23 AM
Junkers88's Avatar
Are the first generations the only ones that come with roll bars? If so then I'll grab as many as I can while I'm there since I can't tell the generations apart on the runners, or the trucks for that matter.
Old 11-13-2008, 10:29 AM
space-junk's Avatar
the first gens look much like your truck... and yes, they are the only year, in america at least, to come with factory roll bars... they are a very sought after upgrade for 2nd and third gen 4runners...
and the second gen runners and third gen trucks are waht matt116 and my runner look like...
Old 11-13-2008, 10:49 AM
Skinsfan6's Avatar
The front legs mount on top of the inner fender. THe rears mount on the floor. Get as many as you can.
Old 11-13-2008, 12:50 PM
space-junk's Avatar
im kinda excited if you get more than one... ill be first in line to guy one off ya!
I CALL DIBS!!!
Old 11-13-2008, 12:55 PM
Matt16's Avatar
Having flopped my truck once, this interested me. One thing though, in its current state, the 2nd gen 4Runner will fit a sheet of plywood most of the way in. The roll bar would prevent that I would think.
Old 11-13-2008, 01:52 PM
yotasavg's Avatar
for sure! that's a really good point....makes me think twice about wanting one of those
Old 11-13-2008, 02:05 PM
Junkers88's Avatar
Ok the plan is this. If I don't go wheeling Saturday morning then I'm going to the junk yard thing instead. I have to get some other things while I'm there but the first thing I'll do is case the joint and grab every roll bar I can find, well to a point anyway...... I don't want to walk out of there with 6 or 7 of the damn things.
I'll let you guys know how many (if any) I can get home.
Old 11-13-2008, 02:15 PM
olharleyman's Avatar
This how they mount , right to the floor with 4 bolts to each leg.
I have this one in my second gen 4runner the only differance between 1st and 2nd gen I belive is the legs need to be cut and rewelded then mounted to the floor.
On my 2nd gen I made some plates for the bottom side above the tires so they were secured better then just thru the sheet metal of the floor.
If you do get any more then one check shipping to 20764 for me for one I need one more for my other 2nd gen runner , Grayhound to D.C. will work for shipping as well.
If it will slide inbetween the wheel wells you should have no problems.
If you look I belive that you should have no problem with the wood or you may have to wedge it a bit higher on one side or the other but I belive you can still get the plywood inside with little to no problem not sure I have not tryed yet but it should be still pretty easy to fit inside.
Old 11-13-2008, 05:28 PM
space-junk's Avatar
that brings a tear to my eye and a giggle in my throat... i cant wait till i can find a 1st gen bar...
Old 11-13-2008, 06:22 PM
Junkers88's Avatar
Thanks for the pic! Now all we need to do is find one (or three) and see if it'll mount in the rear and not get in the way of my highlift.
Old 11-13-2008, 07:12 PM
space-junk's Avatar
it look like it will deffinately hit the hilift, but thats okay, once you get the bar, you can just mount the hilift to it!
Old 11-13-2008, 07:20 PM
nmtoy's Avatar
Here is the best pic I can find, hope it helps.
Robb
Old 11-14-2008, 10:40 AM
Skinsfan6's Avatar
...Don't all or most of the 2nd gen 4Runners have roof racks? That's a good place for a piece of plywood.
Old 11-14-2008, 11:04 AM
space-junk's Avatar
yea, until you get up to about 25 mph and it tries to fly away...
Quick Reply: 4runner roll bar in a pickup?
