4runner ifs problem i think please help
Old 11-03-2007, 11:55 AM
wncmtnrunner's Avatar
i have a 93 with discos and recently when i turn in 4wheel a knocking or clicking ocurs it sounds like it is coming from the driversside
Old 11-03-2007, 02:53 PM
TORTIS's Avatar
it happens only in 4WD?
Old 11-04-2007, 11:21 AM
yeah only when its in 4wheel and in hi it does a more repetative sound than in lo but it drives fine please help
Old 11-04-2007, 01:21 PM
typical8o8's Avatar
do you have manual locking hubs?
Old 11-04-2007, 01:27 PM
Albert.G's Avatar
most likely your axles toastt
Old 11-04-2007, 01:30 PM
Jay351's Avatar
Sound like your CV joint is broken.
Check out the boots covering the axle, if you see a rip you should replace the joint.
Old 11-04-2007, 01:34 PM
fillsrunner4's Avatar
cv's i would bet as well
Old 11-04-2007, 01:48 PM
typical8o8's Avatar
i was thinking CV's too but shouldn't it still make noise in 2wd if he has drive flanges?
Old 11-04-2007, 05:10 PM
Albert.G's Avatar
if he has manual hubs, the axle doesnt spin, therefore only in 4wd
Old 11-04-2007, 05:26 PM
nate V's Avatar
Seems to me that it could be one of two things wheel bearing or Axle shaft. I have done all four bearings in my truck. The ones in the front only made noise when I ran it in four wheel. When they got really bad they sound like a meat grinder all the time. On the plus side if you have to do the axle shafts they it would be easy to replace the wheel bearings at the same time.
To check the axle shaft just reach thru the wheel well and shake the axle shaft like you were checking the play in a drive shaft side to side, up and down, and back and forth. Any excessive play is a good indication that they are worn out and need to be replaced.
Oh yeah if you do need to replace them then there is a good chance that the lower ball joints need to be removed to do it.
let us know how it works out
Old 11-04-2007, 05:29 PM
93caddyrunner's Avatar
my 93 4runner was recently doing the same thing clicking and knocking in 4wd i though it was the cv and i replaced it only to find out that my ring and pinion gears were completely stripped so u should drain ur front diff fluid and see if there is metal in it
Old 11-05-2007, 01:31 PM
thanks for all the replys i sounds like ill have to be fixing that
Old 11-05-2007, 01:47 PM
but the fact that it does it only when i turn does that meen something diffrent
Old 11-05-2007, 03:41 PM
elripster's Avatar
Clicking noises from CV joints when turning sounds like a classic worn CV to me. Now don't necessary get too worried, I have seen cars drive for 50,000 miles on clicking CV joints. If you can make it go away by unlocking the hubs I'd just get a used shaft and keep it handy.
Checking for worn parts like bearings is never a bad idea but your symptoms really sound like worn outer CV symptoms to me.
Frank
Old 11-06-2007, 02:53 PM
i have the auto hubs what do i do and how much do cv joints run
Old 11-06-2007, 03:17 PM
Albert.G's Avatar
auto hubs or a.d.d
Old 11-06-2007, 04:03 PM
elripster's Avatar
If you have auto hubs, I'd first convert to manual hubs. If you have ADD and want to keep it, then yeah you need to look at a half shaft. Check the boards for used ones or you can just call your local parts store for a reman.
Frank
Old 11-06-2007, 05:43 PM
cvs for go for like $80 but they have like a $90 core charge
Old 11-06-2007, 05:50 PM
AndYota's Avatar
I got a pair of new shafts for $140 without a core. They're Napa, but I've done some pretty good wheelin' since and they've held up really well.
Andy
Old 11-08-2007, 03:56 AM
their what ever 93 4runners came with and they squeak when i go down the road i need the cheapest fix
Quick Reply: 4runner ifs problem i think please help
