4runner console in pickup?
Old 03-20-2007, 08:04 PM
standardbyker88's Avatar
anybody put in a 2nd gen 4runner console into a similar year pickup? i got one at the junkyard. and i know im gonna deepen the compartment, and probably shave some of the switch holder things. but fitment, how does it do? it looks like it wont fit good, but thats easy. any help/pictures?
Old 03-20-2007, 09:38 PM
CoedNaked's Avatar
I am pretty damn sure that the front seats and consoles on Pickups/4runners of the same years (between 90-95 models) are the exact same part models and should fit/ line up exactly. That's seat for seat, console for console. Do you mean something else?
Also, if you are removing your front bench seats on your pickup (Non-SR5 model), and putting a console and SR5 buckets, the holes with welded on threaded nuts to mount the console (theres 4 of them) ARE still in the non-SR-5/bench seat models trucks. You just need to take a pin to the carpet to find where the holes are by poking and finding where the pin penetrates, and then get the right size bolts to bolt it down.
Old 03-20-2007, 09:45 PM
ron86toy's Avatar
It should all fit...I have a 2nd gen console in my 1st gen and it bolted right in.
this is in a 4runner with rear heat also
Old 03-21-2007, 08:07 PM
sweet. ive yet to walk out there and drop it on the tunnel. i already bolted in 85 MR2 buckets. the front outer holes bolted in, the outer rear almost did, but not quite. so i drilled 3 holes, and it all went in really nice. i took alot of pics if you guys want it for a how-to. on the driver side, i bent the mounts some to lift the back of the seat up, so im about stock height. they sink you in a bit more.
anyways, thanks for the info. one i got had rear heat, but i didnt need that stuff obviously. im gonna test fit it in a while.
Dharris1986
28
04-17-2017 03:34 PM
WI Girl
06-25-2015 03:45 AM
infinityisfive
06-16-2015 06:51 PM
Lowviz
07-04-2002 09:43 PM
Quick Reply: 4runner console in pickup?
