4Runner Brake Problemo
Old 03-20-2008, 03:28 PM
purerockfury's Avatar
I have a 93 4Runner and the passenger side front brake
keeps hanging up. I replaced the calipers and new rubber
lines leading to them. They still are hanging up.
Has anyone had this problem? Any suggestions?
Brake proportioning valve?
Any help is greatly appreciated.
Old 03-20-2008, 07:08 PM
bigarms23's Avatar
sounds like the rotor is warped so check thoses first
Old 03-21-2008, 11:26 AM
leebee's Avatar
that can be caused by over tight lug nuts. make sure you check the torque specc for the lugs on your rig.
lee
Old 03-21-2008, 01:16 PM
wible1342's Avatar
I have a 1988 toyota 4runner and the break pedal when pushed gose to the floor. I have replaced the master cylinder and bleed the breaks with no change. I was thinking about doing a full break job with new calipers and pistons but i havent found the time. I was just wondering if anybody has come across this problem and what they did to fix it?
Old 03-22-2008, 11:16 AM
Forgot to mention, new rotors were put on the same
time as the loaded calipers and brake lines.
The lug nuts were also put on with a torque wrench
to avoid over tightening.
Again, it's only the passenger side that's hanging up.
If I sit at a light & let off the brakes, about 15 seconds
later I will hear a thump from that side.
Bleed the Proportion Valve?
Prop. Valve sticking?
It appears that there's 1 input & 2 output lines from it.
That's why I'm thinking it's this.
Any thoughts?
Old 03-22-2008, 07:27 PM
toybota's Avatar
Prob can be the only thing that it is. Heres a scenario theres a piece of rust in you brake valve acting as a check valve. Take it apart and clean it all out. Just an idea but I always have the hardest probs to trouble shoot. I'm in my last year of ME school though so I may over analyze.
Old 03-22-2008, 08:03 PM
CJM
CJM's Avatar
I found that my drums were way outta spec and caused this. We replaced almost everything else up front and never checked the rear really. Fixed the rear and bingo good pedal.
Old 03-24-2008, 05:47 PM
Thanks Toybota, as soon as it warms up. I will
take a look at it. Good luck w/ school.
Has anyone else experienced this odd problem?
... or is my 4Runner the first?
06-01-2021 01:51 PM
Johntom240
7
07-13-2015 12:18 AM
87turboPA
07-12-2015 07:49 AM
87turboPA
07-09-2015 05:58 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 4Runner Brake Problemo
