4runner 3vze problem
Old 09-21-2012, 12:57 PM
jktank's Avatar
I am having an issue with my 3vze and need some help. I did a motor swap and the motor runs it ran fine before swap. At wot it falls flat on its face. But only when going up hill. I had a Toyota mechanic look at it and he found a few issues, but nothing that can fix the main issue. timing is dead on perfect, no vacuum leaks. Tps is good to go. Any one that has anything I can try please help.
Old 09-21-2012, 03:18 PM
scope103's Avatar
Compression check.
Leakdown check.
Expectations adjustment.
Old 09-21-2012, 04:20 PM
ThatGuy1295's Avatar
Ya what do you mean falls on its face?
Old 09-23-2012, 02:06 AM
Slowey23's Avatar
Try fuel pressure either pump or regulator, O2 sensor maybe?
MMA_Alex
25
04-18-2017 05:07 AM
Jnkml
07-06-2015 01:20 PM
karbin
07-05-2015 11:37 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 4runner 3vze problem
