4runner 3.0 problems... HELP - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-04-2008, 05:45 PM   #1 (permalink)
HAWAIIANSTYLE's Avatar
i just finished up my new head gasket job and started up my 94 4runner 3.0. it cranks but doesnt turn over. timing belt was set on all the correct markings, tdc @ zero and rotor pointing @ #1 spark plug position. could a vacuum leak cause it not to turn over. still looking for a detailed diagram for the plenum which all the vacuum hoses connect to. please help
HAWAIIANSTYLE is offline
Old 08-04-2008, 06:41 PM   #2 (permalink)
wrnchplr's Avatar
Quote:
Did you try searching?? I know there are a few places to find the diagram.
there should be one on the hood also. A leak won't stop it from turning over only from starting.
I just rebuild a 3.POS and it too won't start. check all the grounds, make sure the one on the back of the right head is hooked up.
make sure your dizzy is correct. I should point at the #1 post on the cap not at the spark plug....Good luck with that......
wrnchplr is offline
Old 08-04-2008, 09:01 PM   #3 (permalink)
wrnchplr's Avatar
so after reading both your post I got an idea of your problems. Now I would suggest getting a FSM, there are some likes here for that. There is a fuel return line that could get hooked to a vacuum port and suck tons of gas into the engine. I am sure your problem is timing as most no start 3.POS issues are from that. pull the bolt from the dizzy and turn the dizzy while cranking the motor over. check the grounds, there should be 4. 3 on the engine and 1 from the body to the - of the battery.
wrnchplr is offline
Old 08-04-2008, 09:20 PM   #4 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
the dist. rotor has to point at #1 plug when the #1 cylinder is at TDC of the compression stroke... you can verify that by checking the valve clearances of the #1 cylinder- both should be loose- i.e.: the cam is not actuating either valve.
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 08-07-2008, 07:47 PM   #5 (permalink)
okay so i double checked the timing again and all the marks are lined up perfectly. had a friend rotate the dizzy while i tried starting it but still doesnt fire up smoothly. once started, i keep having to pump the gas a few times to keep it running and then it dies out. im guessing its something with the fuel. would this be the cause of a bad charcoal canister? im getting a strong smell of gas fuems from the engine. or am i overlooking the fuel injectors.
Old 08-07-2008, 10:21 PM   #6 (permalink)
zlathim's Avatar
Check that fuel return line as someone else has mentioned. Here is a picture that shows all of the lines in the right places:
__________________
Do you think Einstein walked around thinking everyone was a bunch of dipsticks?
Idiocracy (edited for family friendly viewing)
zlathim is offline
Old 08-07-2008, 10:26 PM   #7 (permalink)
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Sounds like a big vacuum leak. It's happened to me on several occasions where I left the brake booster line uplugged.
__________________
Matthew
Context is everything....
Quote:
Originally Posted by abecedarian View Post
freckles, shmeckles... that was your acne reflecting on my pearlescent skin.
Get smacked....join chat!
http://www.yotatech.com/misc.php?do=flashchat
thook is offline
Old 08-07-2008, 10:34 PM   #8 (permalink)
zlathim's Avatar
Quote:
He said he is smelling strong gas fumes. I bet there is a vacuum line hooked to the fuel return nipple under the manifold.
__________________
zlathim is offline
Old 08-07-2008, 10:46 PM   #9 (permalink)
woops, sorry i didnt read all the way through
brentcole5 is offline
Old 08-07-2008, 10:50 PM   #10 (permalink)
thook's Avatar
Quote:
Engh....I was thinking he meant rich exhaust.
Yeah...there's no telling. Pics would be good.
__________________
Matthew
thook is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
88 4runner problems Myers504 4Runners-1st gen 0 07-12-2008 06:57 PM
91 4runner got some problems bullrider3133 86-95 Trucks & 4Runners 10 05-13-2008 08:29 AM
91 4runner problems 4runnerguy 86-95 Trucks & 4Runners 1 11-09-2007 01:17 PM
O/D problems? (90 4Runner) mmof3bys 86-95 Trucks & 4Runners 10 08-12-2007 08:44 PM
4Runner Problems J Rock 95.5-2004 Tacomas & 96-2002 4Runners 6 09-26-2003 10:12 AM
2009 InternetBrands, Inc.
