4 wheel drive problems
Old 03-27-2011, 07:21 PM
runs-on-4's Avatar
i look at a 86 pick up today , everything was good during the test drive until it went into 4 wheel drive. it sounded like the drive shaft was binding up and making the whole truck bump. what could this be from
Old 03-27-2011, 07:29 PM
T_F_E's Avatar
Were you on pavement, did it occur when turning if so thats normal and dont do it again. Other words you might have different tire sizes or even gear ratios.
Old 03-28-2011, 10:44 AM
runs-on-4's Avatar
I tried it on pavement and gravel going straight and it has stock gears and 33's and it only happens when the hubs are locked
Old 03-28-2011, 11:00 AM
justin_4runner's Avatar
i had a problem like that and it was bad cv shaft, but if the u joints are bad that could cause it too.
Old 03-28-2011, 11:02 AM
Bojangles's Avatar
4-low always binds up just a little bit at full turn, But going straight there shouldn't be a problem.
Either there are different gear sizes front and rear, or your cv's could be bad.
(Assuming its something small)
Old 03-28-2011, 12:46 PM
runs-on-4's Avatar
could the cv's go bad from sitting the guy hasnt driven it for a year or two
Old 03-28-2011, 12:51 PM
runs-on-4's Avatar
and he said everything worked when he parked it
06-01-2021 01:51 PM
Avenged
07-09-2015 07:55 AM
colinmil
07-06-2015 04:03 PM
Jnkml
07-06-2015 01:20 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: 4 wheel drive problems
