4" Pro Comp Stage I Lift
If I was going to go with a Procomp I would get a stage 2...
By using the tabs instead of full length brackets you really need the braces to re-enforce the front end or else (at least IMO) it will be too weak to beat on.
Superlift, Rough Country and Skyjacker all use full length brackets that should be a lot stronger than the tabs the Procomps use...
Of course, you could probably weld the tabs to the crossmember and make it as strong as one of the others, but if you lack welding skills then I'd go with a stage 2 lift...
Oh and btw, any 4" lift will let you run 33x12.50's. Just be careful of the back space of your rims. They need to be 3.75" or less if I recall correctly.
None of those bracket lifts are particularly strong.
They're most for milder wheeling and looks.
Out here in the big rocks (southern AZ) they simply don't stand up, if you play in the big stuff.
This is not unique to just bracket lifts for Toyota's, but to bracket lifts in general.
I can't count the number of 'em I've seen bent up after a run on one of the tougher trails that we play in sometimes.
Fred
Fred
Fred
Fred
we all build our trucks for different pourposes.
someone who commutes alot might install highway gears and some 31" street meats. -or- if he off roads on the weekend while hes not at the office he might just install some bjspacers and some shackels on it with some 32" all terrains under it.
me? well im surrounded by good 'ol florida mud. but i also have a 30 minute commute to college everyday. so i got two 2nd hand ifs lifts off of a guy that one toned/ 44" sts's/ SB350/ 350turbo'ed his 89 dlx ext cab. (which would never make a 30 minute commute to work everyday.)
so i installed the 4in and decided to just hold onto the 3.5" rancho since its rare. i still run my 31's during the week so i still get ok gas milage. but whenever i wanna go mudding i have my 33's ready to bolt up an go.
and say someone like you, (or anyone else in the west, or into rocks.) your going to build your truck to have as much flex as possible. sas/ springs or coil overs that yeild huge travel/ 36, 37, 38" irocks or something of the sort, and probably even an exocage if your that into it.
to each his own.
Here is a more functional way to get about 4" of lift.
2 inch body lift~150$ Summit Racing
1.5 inch balljoint spacers~120$ 4Crawler (BTW those allen heads are RUSTING in South Texas no less)
.5 inch torsion in my case over 2" bar crank~ as long as it takes you to figure out how to do it
3 inch rear spring~250$ Downey
2 inch rear blocks~18$ O'Reillys with connections
So about 600$, this is easier work, probably better quality springs, the BJ spacers can help the front actually flex a little and your Center of Gravity or COG isn't raised as much because of the body lift. And this is with 35x12.50's on 10 inch wide rim with 4.00" backspacing.
And believe it or not, I love it the way it is...
I'm up about 8.5" in the front and almost 10" in the rear because I've been too lazy to redo the back. Eventually I'll lower it to match the front but for now it doesn't bother me too much.
Total breakage in the year since I did it: $0.00.
Here's the thread where we went out there. I was with a few guys from the T4R forum. Check out the Lexus in the mud!
http://www.toyota-4runner.org/showth...threadid=32135
And the link to Hard Rock...
http://www.hardrockmx.com/index.htm
It was over at Hard Rock MX park. They have a 4x4 section that is a great way to try a little bit of everything. It's been a while since I've been out there. If you want to go PM me.
There is probably going to be a FATTShack outing at Hard Rock sometime around Thanksgiving. I'll probably be heading out there. I'll post more info as it gets closer but just wanted to give a heads up.
I have a ProComp Stage II lift fo sale. Kit recomend 33 12.5's and 3.75 back space on rims but you can run 35's. So any how kit is completely brand new in original boxes with front stainless skid plate and high energy master bushing kit.
JookUpVandetti
7
09-10-2015 08:56 AM
FS[PacNorWest]: Take off Tundra and other Toyota Parts
justdifferentials
09-08-2015 03:13 PM
punks_is_4x4
08-21-2015 01:35 PM
