4 inch rough country lift need ideas for a better rear setup!
Old 09-19-2010, 06:52 AM
ethanp123's Avatar
i have an 86 4runner with a 4inch rough country suspension lift. My main problem is i keep bending and breaking leafs in the rear. My current setup is a stock toyota leaf with an ad a leaf, and a 4inch block. Wondering if anybody had some suggestions on a better setup for the rear? I was thinking about swapping over to 63" chevy leafs but i think i would need more then just the leafs to even out with the front!
Old 09-19-2010, 08:10 AM
elblako91's Avatar
If you do extreme offroading I've read blocks are a big especially a 4 inch block!
Old 09-19-2010, 08:49 AM
BajaRunner's Avatar
The best setup would be to get a new spring pack. They are pricey though. Marlin Crawler, Trail Gear, All Pro all sell them.
Old 09-19-2010, 09:00 AM
camo31_10.50's Avatar
the 63" chevies should level you out.
at most you might need a 1" longer shackle.
Old 09-19-2010, 09:59 AM
muddpigg's Avatar
Either 63" chevies or Allpro, Marlin, or trailgear will serve you well. Both require moving spring hangers.
Old 09-19-2010, 10:04 AM
yodercrawler55's Avatar
i have a 3" rough country lift and i beat the living crap out of my truck and have no problems except one of the front leaf packs is slightly bent after stuffing the wheel into the wheel well so many times. just do new leafs in the rear add a leaf and blocks are for road queens not for real wheeling. just my 2 cents.
Old 09-19-2010, 10:05 AM
BigBluePile's Avatar
Get some super lift springs and 5" shackles.
Blocks are BAD mkay...
Old 09-19-2010, 11:05 AM
myyota's Avatar
Here is a picture of my 86 4Runner with 5'' lift 63'' chevy springs, they would would work a lot better than the set up you have now, but you will need to move the spring hangers to make them work.
Old 09-19-2010, 11:06 AM
myyota's Avatar
06-01-2021 01:51 PM
Kalihi,HI
07-09-2015 04:29 PM
God's Bounty Hunter
07-08-2015 12:54 PM
MTLroadierunner
07-06-2015 12:17 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: 4 inch rough country lift need ideas for a better rear setup!
