4 inch lift
4 inch lift
i have he chance to get a 4 inch suspension lift for dirt cheap but am deciding on weather i want to go that high as my goal is to run 33s which i know i can with this but ive also looked at the ball joint spacer lift does anyone have any pics of either the 4 inch lift or the ball joint spacer lift so i can decide thanks
In my opinion, BJ spacers should only be used for increasing wheel travel and not for larger tires. They allow full suspension compression so a tire that rubs the fenders without the spacers will still rub with them if the suspension compresses enough.
here's my '88 with 4" ProComp bracket lift, ProComp 4-5" lift leafs and 2" longer than stock shackles with 31"-ish tires:
*the bent rear bumper caused by a Toyota Matrix trying make a new type of Toyota Hybrid.
coffey50
07-28-2015 10:55 AM
