4" 95 Runner Suspension Lift(s)
Old 06-09-2009, 01:21 PM
YotaRunner2wd's Avatar
Thumbs up 4" 95 Runner Suspension Lift(s)
I am looking for lifts for my 95 4runner 2wd auto. obviously, all bodu lifts i have found are for manual tranny, so i am stuck without a BL. i am now researching suspension lifts and the only ones i have found that fit a 2wd 95 auto are a Superlift 4" and an Extreme Suspensions 4". Both are about 1100-1250 $ depending on where and who i buy from.
1: Has anyone tried either of these setups, and if so, how good are they?
2: Does anyone know of any other lifts for my setup that will lift 3" to 4", or allow me to fit at least 32s?
Old 06-09-2009, 01:23 PM
ovrrdrive's Avatar
4crawler has a body lift available for auto equipped trucks... It's your cheapest route.
Old 06-09-2009, 01:32 PM
is he a member, any website, sorry, newb here
Old 06-09-2009, 01:40 PM
Lummpus's Avatar
heres a link to 4crawlers website
http://www.4crawler.com/4x4/ForSale/ProductLine.shtml
Old 06-09-2009, 01:47 PM
Sponsor
Tofer's Avatar
also you should be able to run balljoint spacers and LC coils
Old 06-09-2009, 01:48 PM
thanx man
Old 06-09-2009, 01:53 PM
Countryhick's Avatar
Originally Posted by YotaRunner2wd
thanx man
im running a 4inch supsension on 33's and clear 35's with no rubbing.
so with 32s i would go the body lift because 32's with a 4inch would look to small.
Old 06-09-2009, 06:17 PM
Tragic Drive's Avatar
http://www.chaosfab.com/92100.html
Old 06-09-2009, 08:14 PM
abecedarian's Avatar
95 2wd 4Runner has the same basic suspension as a 4wd 4Runner and should be able to use the same bracket lift (minus the differential drop parts) so that should open up a few options for lift.
Body lifts are pretty much out of the question save for 4Cralwer's lift. You might be able to install another kit but will have some fabbing to do for the shift linkage.
Old 06-09-2009, 08:31 PM
anthony1's Avatar
You can actually run 32's without any suspension lift....maybe get ball joint spacer or cranked the t-bar a little.
Old 06-10-2009, 12:59 AM
ovrrdrive's Avatar
I ran 32's on my truck with no lift and ended up cranking the heck out of my tbars and it still rubbed bad enough to rip off my mud flaps one day turning around in a parking lot. After I put on a 3" bl I was not only happier, but the truck was more capable and easier to work on as well. I see you're on the stock rims too. Maybe that was the difference...
Old 06-10-2009, 07:51 AM
anthony1's Avatar
It does rub a little in full turns but not too bad.
That pic was so long ago.....
06-01-2021 01:51 PM
God's Bounty Hunter
07-08-2015 12:54 PM
Jnkml
07-06-2015 01:20 PM
HRDC0R19
07-05-2015 06:43 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: 4" 95 Runner Suspension Lift(s)
