4.88's with 235/85r16's??
Old 06-22-2009, 03:31 PM
AZ89LONGBED's Avatar
I am ordering a set of 235-85-r16's to run on my Taco wheels, will 4.88 gears be too low for highway use?? The tire diameter works out to just shy of a 32" tire. I know 31's run 4.56's and 4.88's generally go with 33's, am I going to lose a bunch of driveability?
Old 06-22-2009, 03:54 PM
Tubbyfatty's Avatar
Naw I think you will be just fine.
Old 06-22-2009, 05:05 PM
KVRunner's Avatar
You will probably enjoy the extra acceleration
Old 06-22-2009, 05:20 PM
Has anyone actually run this setup??
My truck has a fiberglass camper shell and often I carry tools, highlift, 2 spares, extra water, etc. I do pull a 14' aluminum with a Honda 90 on occasion, and I do live at 7,000' elevation. In the future my truck will most likely get heavier with sliders, bumpers, etc as well...
My concern is to not be revving too high on the interstates.
Old 06-22-2009, 07:26 PM
GenXr's Avatar
You got a manual tranny? You should be fine with those tires and gears.
I've run the math on those gears a ton of times and that size tire shouldn't give you any problems.
Old 06-22-2009, 11:21 PM
Jay351's Avatar
Youl be fine, you arent gonna go much past 70 anyways, right?
Old 06-22-2009, 11:40 PM
I'm just under 3300 rpm at 75 according to an online gearing calculator, which would be the fastest you can drive around here anyways, on the interstate. That would be a gain of 200 rpm from my current setup with 4.10's & LT235-75r15's. It will be a bit of a dog until I get the gears done, but I already have a 4.88 diff sitting in my garage, just need to get a 4.88 rear third...
Old 06-22-2009, 11:44 PM
Jay351's Avatar
Well, I have always looked at it this way. You will get nice acceleration, and well its a truck. It ain't gonna be fast on the hwy. As long as it gets you there fairly quick
low gearing is so much fun in the city and off road Its also nice to have grunt to pass somebody on the hwy.
Old 06-23-2009, 12:54 AM
abecedarian's Avatar
keep in mind fuel economy depends on TWO things:
RPM's and how far you press the pedal.
If you can keep your speed without pressing much on the pedal, you're doing well.
Also, keep in mind that many people choose gears so they have power when they need it. That doesn't mean that power=mileage though.
Overall, the least amount of throttle required to maintain your speed is the best you can do to save money.
Old 06-23-2009, 05:41 AM
INFINITY's Avatar
that's exactly what i am running. works great. contact zuk and have him give you piece of mind on the install and he is one heck of a cool guy.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
justdifferentials
14
06-11-2017 08:36 PM
Badlander
10-10-2015 08:05 PM
JookUpVandetti
09-30-2015 08:58 AM
AkitaDog
09-03-2015 09:01 PM
Quick Reply: 4.88's with 235/85r16's??
