4.56 vs. 4.88
4.56 vs. 4.88
i have recently checked the gear listing on my factory tag in the door jam of my 90 4runner and discovered that i have stock 4.56 gears. i am running 33" x 12.5" rubber and i was informed i should be running 4.88 gears to maintain closer to stock power. i was also told by an un-named parts guy that there is not a big enough difference between the gearings to bother swapping... how true is this? i have already purchased a ifs front diff with 4.88 so i would be pretty disapointed to if it was a pointless buy.
There really isn't enough difference between 4.56 and 4.88 to justify spending the money. Many times, gear swaps are online created hype. I am still running 4.10 gearing on 33" tires with no problems.
If you really want to better your situation, get a set of 5.29 gears. Or, just leave alone what you have. Its not worth the money or time to swap out for .32:1 more ratio
actually if he played his cards right he could sell the 4:56's to compensate for the price of the 4:88's. even a .10:1 jump would help the 3 slow.
but DC does have a point.
5.29's are considerably more expensive and tougher to come by, right? would they not also bring my rpm quite a bit higher? i have found that the 4.56 with 33's have basically eliminated the use of 5th gear and towing seems like a big strain on my lil 3.0.
maybe 5.29s are the answer?
on a side note, if i do a 3.4 swap what gearing is best in that situation?
If the 4.56's aren't causing you any real grief I wouldn't bother changing them. The speedo error isn't that much but you might want to clock your speed with a GPS so you know how far it's off (to avoid any popo issues). If you do change them out, do like DC said and get something a little more worth your while.
Since you're having top gear and towing issues then maybe a swap would be advised though.
I'd just run them for now, but keep an eye out for a used set of 4.88 thirds. Sometimes you can get lucky and get them pretty cheap. You can occasionally come across someone on craigslist who is parting out a 4runner or pickup with factory 4.88s and doesn't even know they have the 4.88 ratio.
So if you find a set of 4.88s for a good price, then can sell your 4.56s for a similar price, you can potentially upgrade for very little, if any, cost. Just throwing another option out there. If it were me, I wouldn't bother
i'd had the same thought. the thing is, i already have the ifs 4.88 front sitting in my garage so i am just waiting for a rear third. but at the same time if its a waste of effort perhaps i should pursue 5.29's to compensate for my lost power.
Sorry for a little highjack.....but...
Would I notice a difference from 4:10 to 4:56? I run 31's and don't plan to go any bigger but thought it might help when pulling my ATV and wood. I have a full set from a 4runner that I am scraping but it is a bit of work to change the front diff.
I do commute with it though so I don't want to be revving to the moon.
How about me and my 3.9's on an Auto going to 31's. I am trying to find a factory 4.88 third if not gonna suck it up and go 5.29 gears and lockrite installed at the same time.
i am going to go ahead and swap.
once i find a rear 4.88 for a good price i will be selling my 4.56's
i am still curious to what the best ratio for a 3.4?
would it be the same as a 3.0?
Those who say it isn't a significant difference for the money have never done it.
For me, 4.56 and 33's was OK, but changing to 4.88 was NIGHT AND DAY. All that said, now that I live at altitude, I wish I had 5.29
lol i drive in 5th gear around town with 33 swampers and it was fine until there was a bigger incline
I agree. It's pretty cool driving something with 35s on steel wheels that feels like it did when it was stock. It's not just the power you get back...the comfort level increases.
ashamsuddin
17
01-13-2023 03:17 AM
justdifferentials
Just Differentials
06-13-2022 07:40 PM
JookUpVandetti
09-30-2015 08:58 AM
