4.3 swap....timing cover
Old 03-09-2014, 11:20 AM
Goju Guy's Avatar
I am putting a 96 4.3 in my 87 4runner. I am going with a carb'd setup. So my question is which timing cover can I use? I will have to use an HEI dizzy setup and adjust timing to 10 deg BTDC. The stock timing cover only shows TDC. I noticed a timing cover from a 85 astro van has the timing marks on it. Will it bolt up to my 96 4.3?
Any advise would be great!
Old 03-09-2014, 11:22 AM
Goju Guy's Avatar
Also, I am needing to get a 153 tooth flywheel; any suggestions (make/model/links) and an appropriate pressure plate. Again, any advice would be very welcome.
Old 03-09-2014, 06:00 PM
james92toy's Avatar
Not sure but i think the 85 cover should work , Make sure its the same shape and number of bolts. Put your motor at 0 degree put 85 cover on and see if it lines up with harmonic balancer line . Post this in engine swap. Another guy just put a 4.3 to a toyota 5sp maybe he will tell you what flywheel to use or call advanced adaptors.
RyanJ989
11
04-07-2021 09:41 AM
Jason4X4
09-17-2015 08:02 AM
Corvoid
09-14-2015 10:10 AM
Dparr2ndgen
09-08-2015 01:06 PM
Gone Fission
09-04-2015 12:18 PM
Quick Reply: 4.3 swap....timing cover
