3vze wont start after timing belt change
Old 10-28-2010, 03:28 PM
alex81290's Avatar
I searched around and couldn't find anything to answer this question, but I just changed the timing belt on my 94 toyota pickup with 3vze, and in the process changed the transmission fluid/water pump. now when I try to start it, the starter motor engages and all the belts by the fan move, but it wont fire.
I did mess up the timing just before the new belt went on, but the cams are lined up correctly now.
any ideas what the problem could be? (or if I could have messed anything up with the recent work?)
EDIT: seems like it had no compression, any ideas?
Thanks,
Alex
Old 10-29-2010, 01:17 AM
TNRabbit's Avatar
Are you 180 degrees off on the cam timing?
Old 10-29-2010, 08:26 AM
alex81290's Avatar
I dont think it is, the notches were lined up correctly. Although the gears on the cams were different (had different marks on them). I am going to do a compression test when I can, it sounds like there is no compression now.
voiddweller
19
05-02-2016 09:10 PM
vasinvictor
01-20-2016 12:39 PM
serenity03k64
06-27-2015 07:59 AM
marcusSRG
06-27-2015 07:13 AM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: 3vze wont start after timing belt change
