3vze Valve lash
Old 02-28-2014, 11:21 AM
alopez620's Avatar
3vze Valve lash
Hi I have a 94 3vze i was wondering if you could set valve lash with the heads off the engine. and if so do i have to recheck valve lash after i remove the cam to put the heads on then reinstall the cam.
Old 02-28-2014, 11:31 AM
james92toy's Avatar
When heads are on the bench put cam in just like it was in the truck to set valve lash. It will be the same when you put heads back on motor.
Old 02-28-2014, 11:54 AM
Sturmcrow's Avatar
On a lot of engines you should do the valve lash on the motor, but that it because you set it hot. The 3VZE is set cold, so you are good to go.
Old 02-28-2014, 11:57 AM
alopez620's Avatar
Thx for the info. exactly what I wanted to hear.
foampile
12-18-2022 01:29 PM
JHalcyonM
03-06-2019 08:37 AM
ManzDaKlown24
08-22-2015 10:25 PM
Dennisx2
08-10-2015 06:48 AM
Dennisx2
08-04-2015 01:26 PM
Quick Reply: 3vze Valve lash
