3VZE Timing Redo
Old 06-19-2009, 03:20 PM
dcmbsc's Avatar
3VZE Timing Redo
I went in and changed the knock sensor and all the gaskets and put it all back together and it wont crank. I clecked the wire I unpluged and cleaned them and I am getting spark.
Heres the strange part, throwing no codes. If I take the 15 efi fuse out and then put it back in , try to crank it and it trys hard for the first couple seconds then gos back to just barely turning over. Ive redone the timing 2 times..
What else could be wrong?
How do you redo the timing from Nothing, just redoing it all the way?
Old 06-19-2009, 04:20 PM
tater669's Avatar
make shure you are not 180 out on timing got to be on the compression stroke, if you have a compression checker check one of the cylenders to make shure if you dont have any compression your 180 out i have been down that road on a new motor ...
Old 06-20-2009, 04:11 AM
TNRabbit's Avatar
Wait; it's just barely turning over? That indicates a battery or starter issue...
What all did you do to the truck? What gaskets are you talking about replacing...head gaskets as well?
Old 06-20-2009, 06:07 AM
tater669's Avatar
true TNRabbit, I misread on that!!! Yeah it sounds like the battery or starter issue or did you have any ground wires off or such ?
icentropy
09-16-2020 02:47 PM
smiley52
07-11-2015 05:16 AM
MTLroadierunner
07-06-2015 12:17 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: 3VZE Timing Redo
