3VZE starting/stalling issue...
I've got another '94 PU, w/ a 3VZE and 160k... Nice truck, but I've not had it very long.
A while back, I ran it out of gas (whoops!) and now it either won't start, or if it does, won't run for very long. So far I've checked for spark, changed the EFI relay and the fuel filter, but the problem still persists...
My 22RE had a bad fuel distributor once (@ ~205k miles), and I recall the mechanic who worked on it cursing me because he had to drop the tank twice to fix it (thought it was the pump first)...
Could either of these be the problem on my "new" 3VZE, and if so, is it worth it for me to take the time to drop the tank myself to fix it?
-Johnny
-Johnny
It sounds like there was something wrong with the pick-up filter screen in the tank and you have some crud in the fuel line... FWIW I've ran mine dry more times then I care to think about with no problems but I know that my tank is VERY clean inside [I had to drop it once to put in a new fuel pump/sending unit] so that [crud] is not an issue for me...
You may need to get the fuel system power flushed or else a new fuel pump/sending unit...
hope this helped aviator
What Aviator said is a definite possibility, but you can try this little test.
Take a paper clip and put either end into the two terminals labled "FP" and "B+" in the little, plastic grey box located over the pass. side wheel well. It will be labeled "diagnostic box". This is jumping or bypassing the circuits that operate the fuel pump within the EFI....or essentially "hardwiring" the fuel pump. This way you can determine if the problem is within the circuitry and not a blockage in fuel delivery. If it will run and not die, then begin testing the VAF meter (volume airflow meter) according to the FSM instructions. If it still continues to die on you, then it's either the pump itself, the fuel filter, or as Aviator suggested.
http://personal.utulsa.edu/~nathan-b...92volumeai.pdf
Thanks a ton for the info guys. I'm not a noob when it comes to VW's, but the 'Yota's have required so little maintenance since I got one, I just haven't had the need to dig into one...
Unfortunately, I've dropped it off w/ the aforementioned mechanic, because I have ZERO time this week to look @ it, and I have a brake job to do this weekend (among other things)... I'll print out your suggestions and drop them off w/ my tech.
Peace,
Johnny
Peace,
Johnny
lol we come from the same family, its nice to not have to fix things everyday
although i miss my dub more then ever time for another one, i think your fuel filter is just plugged up, could have sucked up rust/dirt
Already changed the external filter, but the in-tank filter/screen may be clogged...
Yep... My "check" for spark entailed spraying starting fluid (ether) in to the throttle-body. It happened to work so I determined spark was "good"... Spoke to the mechanic this morning, and he thinks it's ignition related. If I'd had more time, and a little help, I'd have done a little more thorough diagnosis myself.
