3vze: Shim stuck to bucket
Old 12-10-2008, 10:20 PM
LotOMiles's Avatar
Ok, so how do you get the shim off the bucket? I got the valve held down and I can spin the shim around, but it won't come off. The bucket only has 2 slots in it, not 4 like in the FSM. So I have no way to try and pry the shim up. Even a magnet will not get it up.
How do I get the shim out?
Old 12-11-2008, 02:43 AM
TNRabbit's Avatar
There's a linky to the FSM for '93 truck at the top of the forum. If I'm not mistaken, it takes an SST....
Old 12-11-2008, 02:48 AM
ahickman's Avatar
Used compressed air! Put the nozzle right against the notch in the bucket and stand back. Just be carefull that the shim does not drop down in the ports of the head when it blows out. Use a rag or paper to block the holes.
Old 12-14-2008, 06:09 AM
LotOMiles's Avatar
Compressed air is brilliant and does the trick. Thanks a bunch.
kawazx636
10-06-2021 03:03 PM
Redeth005
06-28-2018 08:16 PM
LotOMiles
09-14-2015 11:45 PM
Quick Reply: 3vze: Shim stuck to bucket
