3vze sensor help please
Old 06-01-2013, 12:59 PM
65094runner's Avatar
I was driving home the other day and started to smell a rich smell. Then a loud electric whineing when I pressed the gas.
So I pulled in the driveway smoke coming from my hood. Opened it and found that there was a leak at the back of the engine. It was dripping onto the exaust and smoking off explaining the weired smell. After researching I found that it could be the coolant bypass hose. I picked one up from toyota today.
Attachment 92656
So I'm going to fix that but I also noticed a sensor hanging with two hoses in it. Doesn't look like it should be like that anyone no what it's called? Here's some pics
Old 06-01-2013, 01:42 PM
MudHippy's Avatar
TVV(Thermo Vacuum Valve), sometimes refered to as a BVSV(Bi-metallic Vacuum Switching Valve).
Without it being installed in one of the designated coolant ports(it fits several of them), your EVAP system is non-functional. Unless the TVV eventually heats up enough to actuate/open the valve. It needs to reach atleast 129°F. Which may or may not ever happen.
You can see where it's supposed to be installed(the old/broken one is still stuck in the hole/port).
Old 06-01-2013, 05:56 PM
Sweeeet! Thank you for the help I appreciate it
Old 06-03-2013, 03:33 PM
Ok so i got the old hose and sensor off. But I'm stuck.the good thermo vacuum valve won't screw in , the nipples on it are hitting something.i have pictures.
I got one thread on to hold it there but it's being stopped.
Anyone no what I can do?
Maybe sand a little of the nipple off? Will this do any damage to it?
JHalcyonM
03-06-2019 08:37 AM
Flossy
08-05-2015 05:14 PM
88yodabasket
07-13-2015 01:32 PM
smiley52
07-11-2015 05:16 AM
Quick Reply: 3vze sensor help please
