3VZE-Replace head gasket or swap in another engine?
Old 06-03-2009, 07:59 AM
KentuckyMudder's Avatar
Ok, so a head gasket finally blew on my stock 1990 3VZE xcab pickup with 252,XXX miles on it. Would it be worth doing a rebuild (head gasket set, pistons, rings, timing belt, pulleys, oil pump, etc), or should I swap in a remanufactured? Or lower milage engine? What else should I check out If I rebuild? Which one is more cost effective? I love this truck and just started planning some mods when the gasket blew. HELP!!
Old 06-03-2009, 08:23 AM
TNRabbit's Avatar
There are many, MANY long, detailed threads about this exact circumstance/procedure. Search on "3vze head gasket" and ye shall find more than you can read in a couple of hours...
naward1996
04-23-2018 05:23 PM
voiddweller
19
05-02-2016 09:10 PM
jennygirl
11-17-2015 11:24 AM
paxanders
06-21-2015 06:29 AM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: 3VZE-Replace head gasket or swap in another engine?
