3vze pinout help!!!!
Old 10-07-2011, 02:47 AM
Rkozera91's Avatar
Exclamation 3vze pinout help!!!!
Okay so i have a 92 pickup i swapped a 91 3.0 and a r150f tranny in to it.
The swap went well until the wiring part got most of it done only a few wires unsure of.
I have the marlin crawler vss upgrade so i can use the electric gauge setup and have no idea where the vss wires go i do know the b-o is 12v+ g-r is signal and g-l is ground or i might have them backwards besides the point I figured out where those wires go and no idea where the b-o wire goes if any body has a pin-out for the ECU and E6, E7, E8, IH1, and IH2 would be a great help just to makes sure I have all the wires in the right spot.
I spent countless hours searching and no luck i have manuals and diagrams and you name i got but nothing on the vss , that and my backup switch wires where pulled from the plug, that is what happens when you ask your wife for help so not sure which wire goes where.
Thank you for any help you bring to the table.
PS PICS WOULD HELP OUT A LOT
I'll be posting some of what I got so far.
MadMax48
03-03-2020 10:33 AM
Kamaloha
10-16-2015 05:13 PM
alexcarey
10-14-2015 06:05 PM
Matthew Perez
09-28-2015 05:43 PM
Quick Reply: 3vze pinout help!!!!
