3vze oil pan gasket, Cork or silicone? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 12-21-2008, 08:42 AM   #1
motobro's Avatar
Hi,
Installing a remanned 3vze and I am down to puttin the oil pan on. The gasket kit with the motor provides cork, chilton's talks about using FIPG. Will the cork leak, or should I take it apart and use Form In Place Gasket stuff.
motobro is offline   Reply With Quote
Old 12-21-2008, 08:47 AM   #2
INFINITY's Avatar
i would do ultra grey. make sure you prep and prep again your surfaces with brake clean. DO NOT OVER TORQUE OIL PAN BOLTS or it will cause a big headache.
INFINITY is offline   Reply With Quote
Old 12-21-2008, 09:01 AM   #3
mt_goat's Avatar
FIPG is what the factory uses.
mt_goat is offline   Reply With Quote
Old 12-21-2008, 09:11 AM   #4
95RunnerSR5's Avatar
FIPG, the cork gaskets are a joke. i'm speaking from experience
95RunnerSR5 is offline   Reply With Quote
Old 12-21-2008, 09:15 AM   #5
motobro's Avatar
Thanks guys, FIPG itis!
Old 12-21-2008, 09:36 AM   #6
This one time, at band camp
Staff
DeathCougar's Avatar
use FIPG and remember you will need to do the pan AND reseal the baffle plate
DeathCougar is offline   Reply With Quote
Old 12-21-2008, 04:43 PM   #7
I had a local shop install a rebuilt 3.0 last year. The reman people had used a cork gasket which I questioned--they gave me a long song and dance about how they have to do that with rebuilt stuff to compensate for a possible warpage of the oil pan, so I bought it, my son took it to Portland and back and it was gushing oil, pan was about to fall off. I made them re-do it, they used cork again, 500 miles, same thing happened. I said to H--- with them, had the front diff out anyway so I pulled the pan used FPIG like the factory manual sez to do, 3000 miles later, no problems. Never use cork on a 3.0 IMNSHO
morrison is offline   Reply With Quote
Old 12-21-2008, 05:32 PM   #8
abecedarian's Avatar
cork is 'okay' but not the best thing to use. However it can work if installed properly... you have to clean the pan and block very well (you have to do that anyhow), use a high quality oil resistant sealant such as (my favorite) hylomar and not over-torque the bolts... not to mention that the bolts will likely not be long enough to hold very well so some sort of thread-locking compound such as loctite blue or red needs used too.
Or you can use a FIPG (form in place gasket) sealant, which again, my favorite is Hylomar. Gotta love that stuff... you can use it almost anywhere, 'cept exhaust gaskets.
abecedarian is offline   Reply With Quote
*SOLD* 1991 Toyota Pickup DLX 4x4 5 speed 165k, fresh motor,lifted,clean! $6150 GreatLakesGuy The Classifieds GraveYard 8 09-04-2015 10:27 AM
Another timing chain question thefishguy77 Newbie Tech Section 10 07-30-2015 11:59 AM
Found in my oil pan irritech 95.5-2004 Tacomas & 96-2002 4Runners 3 07-27-2015 06:15 PM
Do I bother fixing it? 1993 3vz-E 4x4 Colington 86-95 Trucks & 4Runners 13 07-21-2015 06:24 PM
22RE Leaky Water Pump Gasket Snort 86-95 Trucks & 4Runners 4 07-19-2015 08:03 AM
Tags
3vze, baffle, cork, fj40, form, fpig, gasket, gaskets, install, installing, oil, pan, put, sbc, silicone
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
