3vze no spark
3vze no spark
Someone please help I have tried to chase it down for 2 weeks now. I have replaced vaf, ignition coil, ignition control module, distributor, wires and plugs. I get 12.5 volts into my ignition coil but still nothing any help what so ever would be greatly appreciated.
Hmmm. 2 weeks of replacing every part you can think of, but with no reason to replace any one of them. How's that working so far?
Here's everything I know about igniters: https://www.yotatech.com/forums/f116...gniter-287857/ I suggest you work through some of the tests I've described.
Note that 12.5 volts to the coil means almost nothing; the coil is "fired" by pulling the other side of the primary to ground for a few milliseconds, then "releasing" it to fire the secondary.
toyospearo
02-10-2016 12:30 AM
