3vze mods
3vze mods
anyone know any mods for the 3.0L? i just want better acceleration, cuase i can barely make it up to speed when getting on an uphill onramp to a freeway... when everyone is passing you and speeding their way up the hill i am jsut kinda LAGGING. any help would be good
Well first off are you running oversized tires if so you should
1.) regear
2.) understand that you will never get great highway performance with huge offroad tires
That aside, there's not much on the market for 3.0's. You can look into headers, catback exhaust, and do a search on the ISR mod. Keep in mind that nothing you do is gonna transform this motor into a powerhouse.
1.) regear
Can you fill out your sig with vehicle, mods, tires, etc...?
That would help a lot.
Before everyone jumps on you might I politely suggest you search. Trust, the first 3.0's hit our streets 20 years ago (1988) and the last 13 (1995). This topic has been.. um.. covered.
Frank
Frank
Typically knowing if you have for example installed larger tires helps with things like this. 9 times out of 10 someone approaches the forum with, for example, oversized tires wanting to do engine upgrades to restore performance. To that we respond you need to regear diffs and tune up the engine first... etc... So year, engine.. mods are necessary for us to help you.
Frank
Frank
1 Post
Modifications that will give you satisfying performance:
1) LCE Pro Flow 2 1/4" mandrel bent exhaust.
2) LCE Headers
3) Cams
4) Synthetic oil & Synthetic drive train fluids.
The above mentioned modifications from the few who have done them, will give you more satisfying performance with your 3vze.
2) LCE Headers
3) Cams
TheBFA
02-15-2020 06:55 AM
1994, 312necro213, 3vz3, 3vze, 4runner, afm, cheap, easy, maf, modifications, mods, performance, road, toyota, v6
