Sign in using an external account
| 86-95 Trucks & 4Runners 2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
3VZE leak
#2 (permalink) |
Personal
Sales Rating: (0)
A pic would help tremendously, I think the reason why no one has responded is because they are not sure which one you are talking about.
__________________
'91 Pickup SR5 Extra Cab- 4x4 3VZ-E 3.0L - 281k miles and counting |
#3 (permalink) |
Personal
Sales Rating: (0)
[OP]
Here are some pictures of the leak. It is coming from the pipe that has a black plunger thing at the end of it. In the last picture, it is the pipe directly under the flap I'm lifting and above the white wire.
#4 (permalink) |
Personal
Sales Rating: (0)
[OP]
Another shot of the leak.
#5 (permalink) |
Personal
Sales Rating: (0)
What color is the fluid , does it have a smell ?
You sure it's not just fluid from the A/C condenser ... ?
__________________
90' 4 runner
rebuilt 22re, less than 3K dana 44 and dana 60 ARB's front and rear 5.29 gears turning 37" BFG KM2's Marlin 4.70 rear case |
#6 (permalink) |
Personal
Sales Rating: (0)
[OP]
I think the fluid is motor oil because it looks and feels like it, and I've been having to put in a half of a quart every 2 days. It could be from the A/C condenser. If i park the car for an hour, a puddle about 5" in diameter will form below. I'm just not sure. I don't know much about cars.
#7 (permalink) |
Personal
Sales Rating: (0)
[OP]
Oops. I meant 12 days not 2.
#8 (permalink) |
Personal
Sales Rating: (0)
The last pic shows really well. Assuming you have antifreeze thats nothing to be worried about, it's clear should be just water..
If you get a puddle under that area that is definately not water it's going to be the front axel seals most likely. Not sure offhand what is on that side of the v6 engine otherwise to be leaking fluid. Your engine bay is pretty clean, well dry atleast. Get up under there with a flash light and look for the dark/wet spot. Follow the axel shaft up from the wheel, it'll likely be wet on the underside, well wet all over but, there would be something running down it. Find the drip, follow the run to the dry spot, back up to the start of the wet spot, look for things above dripping, you've found your leak. If you can't tell the difference between water and oil, best to take it to a mechanic. Even better if you have a buddy or someone to give you some pointers available. If your willing post up your city and ask if anyone wants to stop by and have a look with you
__________________
#9 (permalink) |
Personal
Sales Rating: (0)
[OP]
You're right Co 94 it is water. I guess the car going through oil very quickly is an entirely different issue. Why is it leaking so much water lately though? It seems like a pretty significant amount.
#10 (permalink) |
Personal
Sales Rating: (0)
Are you running the AC at all, if so it's just doing it's job. What about the antifreeze, pop the radiator cap off and make sure you're not just running water, could be the heat core leaking.
I really do trust you can tell the diff between water and oil if you say there is a 5 inch puddle and it's oil it's not coming from that tube. Really do look around for wet spots with a light, you need to know if it's leaking or burning the oil. I don't imagine your commute is hundreds of miles a day but it could be.. Oops still thinking 2days not 12 haha. I could do 1k just running back and forth to the city in 12 days, so 1/2 quart isn't great but not too bad. I haven't seen an oil consumption chart for these still looking for one.Oh and for us old farts that forget the title by the time we're thru the first post, engine in the message body next time please.
__________________
