3VZE Idle Speed Control Valve
Old 02-17-2012, 11:53 PM
adamthedroog's Avatar
Could someone please tell me where the idle speed control valve is located?
Old 02-18-2012, 04:48 AM
Levinz11's Avatar
Look about half way down the page 1 or control F ----> idle valve
http://www.pirate4x4.com/forum/showthread.php?t=907763
Old 02-18-2012, 07:29 AM
scope103's Avatar
http://www.ncttora.com/fsm/1993/engine/93throttle.pdf page EG2-239 (the procedure is uncharacteristically obtuse).
This might help to understand what the Air Valve does. http://www.ncttora.com/fsm/1993/engine/82operatio.pdf
Old 02-18-2012, 08:09 AM
MudHippy's Avatar
It's located in/on, and/or is an integral component of, the throttle body . On the bottom side of it, roughly in between the 2 coolant lines that connect to it on each side.
More on coolant heated wax type air valves can be found on page 6 of the following .pdf
http://autoshop101.com/forms/h21.pdf
Old 09-17-2012, 03:11 PM
devo's Avatar
thermo valve fail
anyone out there ever seen a thermo valve fail on a 3.o throttle body: wax has oozed out of the by-pass line and is caked around the connection of bypass hose to throttle body....just wondering....time for a new throttle body i guess
smthwsn357
12-04-2023 02:08 AM
Charecter1
11-06-2023 10:08 AM
coryc85
09-09-2015 06:24 AM
MTLroadierunner
07-06-2015 12:17 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: 3VZE Idle Speed Control Valve
