3VZE Guru's - - Where does this go ?
Hi Guys,
I'm currently working through a list of rectifications from where the previous owner, installed a body lift kit (2inch) and then didn't hook everything up or the harness/hose was to short to reach it intended location.
Thankfully I've sorted 90% of the issues by replacing all the raised body mounts with a standard height Nolathane Kit, but I have a few extra harnesses/pipes/hoses/wires still to sort out !
Ok, on the back of the Inlet Manifold I have this broken off - - silicone'd up port, There is no hose hanging anywhere I can see where it belongs. So where does this missing hose go ????
I've scanned the online manuals & really can't find a clear answer where this pipe goes.... Any help would be appreciated
check out this thread...2nd post has a great pic. https://www.yotatech.com/forums/f116...d-help-253796/
what "hose" are you talking about? the fuel line there?
see if this pic helps at all
Kitty, does this diagram help?
http://www.utoyot8.com/Picture.aspx?...ccode=&ppName=
http://www.toyotapartseast.com/compo...8-11823_2.html
THANK-YOU
Welcome!! I edited the post above with where I got that diagram from....it has all the parts diagrams.
I'm blushing.... lol :-) Have a great day down under!
So to answer my own question.
It goes no-where, its blanked off !!
Actually that diagram is really helpful, can double check routing of a few hoses.
Much appreciated guys......
If you have cruise control that vac line would route along firewall exit out from behind brake booster and it fits into component the one with the white dot
Then tee's up to this vac line with white stripe
Hope this helps. Good Luck
