YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-17-2008, 06:32 PM   #1 (permalink)
3VZE Fuel Leak
My mother recently bought a 1990 4runner 2wd (v6, 112k miles) and last week (on startup) it dumped some gas on the ground...Luckily my grandmother spotted it and we turned the runner off.
Gas was dripping off the bell housing(passenger side), but it stopped...So, I followed the fuel lines up to the engine and nothing out of the ordinary....I kinda figured that much since it was dripping off the bell housing, but you know how leaks can find their way to wierd places before they drip
So, i figured it must be coming from the back of the engine...I'd assume somewhere under the intake manifold, possibly the fuel dampener or injector O'rings? The exposed fuel rail and injectors(drivers side) showed no signs of leaking and the leak was on the passenger side...So, how hard is it to remove the manifold and access the fuel rail? Any other ideas of what it could be?
It doesnt leak all of the time, so its hard to trace...
Thanks
YOguyDA is offline
Sponsored Links
To remove this ad, register today!
Old 05-17-2008, 09:42 PM   #2 (permalink)
Pinch the fuel return line (line going to fire wall not charcoal canister) and it should increase you line pesure and cause your leak.
Hope this helps.
CT
CanadianToy is offline
Old 05-17-2008, 09:57 PM   #3 (permalink)
904_runner's Avatar
Sounds like it could be the Fuel pulsation dampner leaking, happened to mine. Sounds common.
__________________
-Mike
1990 4runner SR5, 3.0 with 249K, 5-speed, 4.56 gears, warn premium hubs, Hella 500's, Rancho 9000's, BFG A/T Ko's, rear lock right, 4" trailmaster lift with lc coils in rear
Soon to come: New wheels and tires, Sliders, CB.
One Day: 3.4 swap!
904_runner is offline
Old 05-18-2008, 09:25 AM   #4 (permalink)
Thanks for the replies guys.
I'll try pinching the line, but im pretty sure its coming from under the manifold.
Anybody else?
YOguyDA is offline
Old 05-18-2008, 10:15 AM   #5 (permalink)
jason191918's Avatar
Send a message via ICQ to jason191918 Send a message via AIM to jason191918 Send a message via MSN to jason191918 Send a message via Yahoo to jason191918
Leaking near the frame rail and spraying on the bellhousing? Just a thought.
__________________
JASON
1992 Pickup V6, 4x4, 5 speed, SR5, 300,000 miles young, every option except automatic tranny
31x10.5 | K&N FIPK | Cherry Bomb | 3" BL | 4 110W KC Light Bar | 6'6" Western Plow | Topper | Tailgate Net | 800W 10" Sony | 850W Sound Storm | 2 4" Obcon | 4 1" Rockford Fosgate Tweeters | 2 High Pass Crossovers | 2 High-Low Pass Crossovers | 2 6.5" Rockford Fosgate | Pioneer 4x50W Head Unit | Mechanical Oil Pressure Gage | Lack of EGR
Quote:
Originally Posted by Elvota View Post
Jason is right.
Quote:
Originally Posted by fishon1213 View Post
Jason rocks!!! :banger:
jason191918 is offline
Old 05-19-2008, 10:33 AM   #6 (permalink)
Its not that extreme.... You can run around town doing errands and maybe 1 out of 5 start ups it will leak. It just drips off the bell housing onto the ground. Its just knowing that its got to pass the exhaust to get there that makes it scary to drive.
YOguyDA is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Help diagnosing oil leak 3VZE saltrig Newbie Tech Section 0 03-31-2008 11:06 AM
3vze ticking....... vacume leak??? kcp00420 Newbie Tech Section 2 03-18-2008 09:58 AM
Why does my 3vze leak coolant after fuel damper replaced pro8cess 86-95 Trucks & 4Runners 2 02-20-2008 02:37 PM
mysterious leak (3vze 1992 4runner) taikowaza 86-95 Trucks & 4Runners 21 03-06-2007 07:23 PM
Fuel leak=vacation bummer. If you smell gas but can't find the leak... Reldnew 95.5-2004 Tacomas & 96-2002 4Runners 3 08-26-2004 09:03 AM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
