3vze egr/pair reed valve delete
Old 06-26-2014, 02:31 PM
lemonth68's Avatar
Did the egr and pair reed valve delete this past weekend. So far so good. Better throttle response, engine temp is down a little and better mpg but time well tell about that. Already had the catalytic converter removed before the egr/pair removal. Next is an intake mod for a more direct air flow. Thanks yotatech for the good write ups and reviews. Oh, I bought the lce kit, didn't need the resistors cause I don't have a temp sensor on my egr but the block off plates are nice and saved me time from making my own. Had to drill the holes a tad larger for the pair reed valve block off plate on the manifold. Could be due to warp or because my engine wasn't completely cold. Either way, thanks
Old 08-29-2014, 09:20 AM
lateracer's Avatar
Update? Thinking about the same thing.
Old 08-29-2014, 02:05 PM
lemonth68's Avatar
Do it. Truck has more pep and just a slight increase in fuel milage. This mod frees up a lot if room under the hood. Making spark plug changes easier on the passenger side. For whatever reason your not happy with it, its completely reversible.
3vze egr/pair reed valve delete-forumrunner_20140829_170255.png
3vze egr/pair reed valve delete-forumrunner_20140829_170339.png
06-01-2021 01:51 PM
JHalcyonM
03-06-2019 08:37 AM
e_richard
07-30-2015 06:50 PM
BK2TFUTURE
07-28-2015 10:01 AM
Quick Reply: 3vze egr/pair reed valve delete
