3vze drive belts - part numbers and where to buy?
Old 02-04-2012, 01:01 PM
Lurker's Avatar
Question 3vze drive belts - part numbers and where to buy?
Hello,
I searched around for a while and consulted the manual I have, but wasn't able to come up with anything. Does anyone happen to have the Toyota part numbers for the fan/PS belt, alternator belt, and A/C belt on hand? This is for a 1995 4Runner with a 3VZE.
Also, can Toyota-brand belts be purchased online? The local Toyota dealership is farther away than what I want to drive. If not, is there a particular "aftermarket" belt manufacturer (AC Delco, Goodyear, etc.) whom you would recommend as a substitute for OEM belts?
Thanks a lot! I appreciate it.
Old 02-04-2012, 01:28 PM
MudHippy's Avatar
V BELT (FOR FAN & ALTERNATOR) 90916-02378-83
V BELT (FOR POWER STEERING VANE PUMP) 90916-02196-83
V BELT (FOR A/C COMPRESSOR TO CRANKSHAFT PULLEY NO.1) 99332-10890-78
For OEM I always buy from 1stToyotaParts.com. But there are many such OEM parts suppliers.
I don't happen to prefer any brand of belts over another. I just go to NAPA (or whichever Auto Parts store is available)and buy what they have in stock. I've never had any bad experiences with any brand of belt in 20+ years of driving. IOW, belts are all the same in my book.
Old 02-05-2012, 07:48 AM
Lurker's Avatar
Thank you, MudHippy. Looks like I was incorrect about the power steering and fan sharing the same belt, it's the fan and alternator... not sure why I had it stuck in my head wrong.
Old 11-21-2012, 02:18 PM
XxX_4_play_offroad's Avatar
couldnt really find any other posts for drive belts so here it is- i bought a 92 yota sr5 4wd 5 speed no a/c and just did the timing belt, water pump thermostat yada yada yada. when putting the power steering belt back on i noticed that no matter how much i pry on the slide bar i cant get the belt tight enough even when loosening both the pivot bolt and slide bolt ??????? but before i started to tear everything down the belt was plenty tight any help would be greatly appreciated
94 Newbie
07-06-2015 04:23 AM
bprice0077
06-25-2015 07:36 AM
Chooch
06-19-2015 03:05 PM
TheManOutside
06-18-2015 03:32 PM
LSUMatt1514
06-26-2002 05:03 AM
Quick Reply: 3vze drive belts - part numbers and where to buy?
